Thread: 2001 special edition gtp issues-need some input
Results 1 to 20 of 22
Threaded View
  1. #1 2001 special edition gtp issues-need some input
    Helping and posting for a friend. 2001 special edition gtp with stock pulley and dhp 1.5 tune with a mild custom tune i had done. Car has cai, 3"dp, stock manis, u-bend delete.
    Has ported gen 3 m90 that gets around 9-10psi. Currently gets constant 2-3* kr.
    So far he has changed/added the following:
    255 walbro fp with rewire
    Fuel filter
    Injectors
    Fpr
    Plugs/wires
    Hi speed fp relay pin 85 bent
    Tested fuel pressure:
    Idle is ~45psi and drops to steady 40psi
    At wot is constant 57-58psi
    Checked for vac leaks but found zero. Idle vac is ~17-22inHg
    We're both boggled. Only thing left is swap pcm with a 2000 gtp PCM from a local.
    He has a zzp afc 1.2 and adding 2% didn't change the amount of kr or fuel pressure at wot.
    edited: buddies car is a 2001 and added he removed the u-bend and that it's a special edition
  1. Trans Issues after adding TEP VB, Input Shaft, and Chain....
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-16-2015, 12:15 AM
  2. Transmission Issues, input welcome.
    By Phlip77 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2013, 03:07 PM
  3. More damn issues.. Any input?
    By blknbstd in forum PCM Tuning
    Last Post: 04-18-2012, 10:15 PM
  4. I have some issues after Top Swap NEED INPUT
    By WindsorGP in forum General Tech Discussion
    Last Post: 08-17-2010, 05:35 PM
  5. I need your input on my 2000 GTP Suspension
    By cprher in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 02:58 PM
