Yes, you can hear the fuel pump working if you're underneath. You can also smell gas if you try to push the pedal while starting.
I asked around and none of us knew that a new throttle had to be programmed. Duh... We're going to try that and see if it helps but I have my doubts. The tech said that the "reduced engine power" is normal if the throttle has yet to be programmed because the system is not recognizing it.
He told us that the key sticking is normal too, so that's good to hear. The old switch did not do that so it may have been part of the problem.
