Thread: AC was ripped out, what useless junk can i take out?
Results 1 to 10 of 10
  1. #1 AC was ripped out, what useless junk can i take out?
    Apr 2017
    Ontario
    Heyo
    So my A/C **** the bed and long story short we put a dummy pulley on, What junk can i remove from the car that the AC used? I don't want to carry around extra weight for no reason. The system has been fully drained. I also don't want to throw any codes. What would you do?
    Thanks
    99 GTP: DIY FWI-3in CDP-rez del-plog-napa spark wires COME ON WILL I WANT MY TUNE!!!!!!<3 Intercooling next
    <3 PROUDLY Canadian / PROUDLY Austrian "Look, Gasoline's perfectly safe.....until you introduce ol Orange."
  2. #2 Re: AC was ripped out, what useless junk can i take out?
    I'd just leave it, the condenser is aluminum and weighs under 5 lbs. The rest of the aluminum lines and dryer is maybe 2-3lbs.
    It's not even worth it to remove less than 10lb's of stuff that you'd never notice.
  3. #3 Re: AC was ripped out, what useless junk can i take out?
    Apr 2017
    Ontario
    Yea but doesn't it have a rad behind the cars rad? Being 3000 plus, don't you want as much as you can get in terms of weight?
  4. #4 Re: AC was ripped out, what useless junk can i take out?
    Antioch, IL
    Your a dumbass
    the condensor is in front of the radiator.
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: AC was ripped out, what useless junk can i take out?
    The condenser is installed infront of the radiator.
    I didn't have working AC for the nearly 5 years I owned a grand prix, didn't care one bit that I have "extra" weight onboard.
  6. #6 Re: AC was ripped out, what useless junk can i take out?
    Apr 2017
    Ontario
    You're* hmmmm
  7. #7 Re: AC was ripped out, what useless junk can i take out?
    Apr 2017
    Ontario
    Very true, if i ever get board i may take it out, not in a hurry. Thanks
  8. #8 Re: AC was ripped out, what useless junk can i take out?
    Dec 2012
    troll land
    Main advantage I found from removing the extra ac stuff was more room for the fmhe and more room to get behind motor when working on it. Also my open cone filter had a Lil more room
  9. #9 Re: AC was ripped out, what useless junk can i take out?
    Mar 2017
    Internet
    The connection point under the brake booster is nasty to get to. If you are willing to cut though..it may be much easier to pull the rest of the AC piping. As for the condensor, you'd need to pull the radiator back and try to sneak it out.
  10. #10 Re: AC was ripped out, what useless junk can i take out?
    Dec 2012
    troll land
    ^I didn't pull my condenser till I changed my radiator
  1. JVC is useless
    By Logan541 in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2014, 12:25 AM
  2. Removing Useless Junk
    By ShadowSwept in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2012, 04:17 PM
  3. Just bought 2000 GTP - Did I get ripped off?
    By Tfreeds in forum General Tech Discussion
    Last Post: 12-19-2009, 12:37 AM
  4. Useless
    By blueguy in forum Track Sessions and Kills
    Last Post: 05-23-2009, 07:38 AM
  5. Am I getting ripped off?
    By 98gpgt98 in forum Off Topic Discussion
    Last Post: 06-16-2008, 02:52 PM
