Thread: Removing Useless Junk
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 91
  1. #1 Removing Useless Junk
    GT Level Member ShadowSwept's Avatar
    Kentucky
    Just looking through my engine bay and found some things that are apparently useless. I'm wondering what all can be removed without causing problems. I'm guessing the cover mounts and the engine lift points, but is there anything else floating around that's unnecessary?
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  2. #2 Re: Removing Useless Junk
    Jacksonville, Fl
    i would advise keeping the engine lift bracets in there for if anything happened to the rack and pinion, trans, and etc. thats just personal opinion. for the most part, everything in the engine bay is useful in some way otherwise it would not be there. the engine cover is the only thing there for cosmetic reasons.
  3. #3 Re: Removing Useless Junk
    Kentucky
    I would be keeping the engine lift brackets, just think they'd look better off until they're needed. My engine cover was off when I bought the car but the brackets that it was mounted to are still there and I'd like to know what all can be removed. Just trying to clean up under the hood a bit.
    2003 Grand Prix GT
  4. #4 Re: Removing Useless Junk
    Alternator brace.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Alternator brace.
    Agreed, also, loose the engine lift brackets, u can bolt them up again if u need to. Rear engine cover bracket is also useless
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  6. #6 Re: Removing Useless Junk
    Heck..if you have to hold the engine up..you simply bolt the chain to the head/block if you need to.
  7. #7 Re: Removing Useless Junk
    Kentucky
    I think someone may have already removed the alternator brace- is that the rod that runs from the alternator to the coil packs? It's not there.
    Just out of curiosity, what's up with these people with no dogbones? Is there an alternate motor mount or can they be removed without issue?
    2003 Grand Prix GT
  8. #8 Re: Removing Useless Junk
    gp's need the dog bones, or else the motor will flop around and damage stuff.
    the alt brace is behind the supercharger and or UIM IIRC
  9. #9 Re: Removing Useless Junk
    Kentucky
    I assumed as much, but I have seen pics of them (on this forum, actually) with no upper motor mounts at all. They're obviously heavily modded, but I was just wondering exactly how their motor stayed in place. I kind of like the dogbones, personally, and was planning on getting some polished ones eventually.
    2003 Grand Prix GT
  10. #10 Re: Removing Useless Junk
    Kentucky
    Nothing connected to the alternator that's not a part of it
    There is a bracket behind the UIM, though. Only thing connected to it is this shield that supports the fuel lines:
    Is this necessary, or can it be removed too?
    2003 Grand Prix GT
  11. #11 Re: Removing Useless Junk
    Feb 2010
    TN
    Forget polished paint them to match body color. It ties then into the color scheme and done right looks great
  12. #12 Re: Removing Useless Junk
    Meh, I just ran the coil pack dog bone.
    It worked fine with poly lowers.
    Except my nervous system hated me.
  13. #13 Re: Removing Useless Junk
    Kentucky
    That one is HUGE on mine, with the extra mount point. Covers half the valve cover .
    2003 Grand Prix GT
  14. #14 Re: Removing Useless Junk
    And it's also aluminum...it breaks easily...so you don't want to do that unless you're running a L67 cast iron bracket.
  15. #15 Re: Removing Useless Junk
    Kentucky
    Can they be swapped? I really don't care for that huge mount, especially if I ever get new valve covers.
    2003 Grand Prix GT
  16. #16 Re: Removing Useless Junk
    Get a Bonneville... lower mounts FTMFW
  17. #17 Re: Removing Useless Junk
    May 2008
    Winnipeg, MB
    Didn't somebody come up with lower engine brackets to delete the dog bones?
    2007 Pontiac Grand Prix
  18. #18 Re: Removing Useless Junk
  19. #19 Re: Removing Useless Junk
    Kentucky
    Bonnieville, huh? It looks like the whole top of that engine is composite .
    2003 Grand Prix GT
  20. #20 Re: Removing Useless Junk
    Krylon wrinkle paint.
    Does a good job of keeping most from noticing the 2.25" intercooler, upgraded supercharger and a few other goodies that would be very obvious otherwise.
  1. Gymkhana 4: Zombies, Fiestas and useless advertising
    Last Post: 08-17-2011, 06:12 AM
  2. Ran out of useless stuff to buy
    By tayl5645 in forum Off Topic Discussion
    Last Post: 08-01-2011, 07:31 PM
  3. Useless posting and you
    By Bio248 in forum Site/Club News
    Last Post: 02-04-2011, 06:01 PM
  4. cops are useless, and apparently so is hand soap
    By Vegas_Matt in forum The Rant Forum
    Last Post: 08-27-2010, 04:44 PM
  5. Useless
    By blueguy in forum Track Sessions and Kills
    Last Post: 05-23-2009, 07:38 AM
