Thread: Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
Results 1 to 10 of 10
  1. #1 Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
    Mar 2017
    New York
    I have a 2004 comp G. . When I accelerate or brake I feel what I can only describe as a Jut in the steering wheel. It feels like there is play in a tie rod or something but I am told all is good. I also have a baseball card n a bike spoke sound when I take long radius turns. I think this is a separate issue but maybe not.
    My mechanic says he has come across this in the past and he has changed tons of parts and it never solves issue. I am not sure what to do.... I have read about strut bolts and possibly starter...which just seems like an idea odd cause and effect.
    Car is in great shape so I really want to do what ever is needed. Your help is appreciated.
  2. #2 Re: Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
    The card sound is a CV axle, no doubt. They always click when they go bad.
  3. #3 Re: Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
    Mar 2017
    New York
    Is there way to tell if it is bad before I replace ? What do you think about Jutting feeling in steering wheel ?
    thanks again
  4. #4 Re: Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Tie rods and such are easier to check. If he hasn't ever found the issue than maybe its something less common. Intermediate steering shaft perhaps?
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
    Mar 2017
    New York
    I actually just changed that because I thought would fix problem....It made it a little better in some areas but clearly not completely solved.
  6. #6 Re: Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
    GT Level Member sugaryuk's Avatar
    vancouver,bc
    Too much play in sway bar end links? or possibly sway bar is cracked? Is it only specific to turning in one direction?
    02 GT- L32/Gen V, 3.3 mps, zz 1.9's, N*, slp front to back, OverKilled, 180 tstat, 104's, K&N cai, lowered with GMMP susp, 12" PBR brakes
    75 Pro-Street Vega-- Blown 383 stroker with Nos fogger system
  7. #7 Re: Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
    Pennsylvania, USA
    My preferred way to check CV joints is to raise the front end (safely of course), disable TC if equipped, and accelerate while holding the brakes to induce a load in the drive line. Obviously don't hold the brakes so hard that the wheels can't spin, you're really just simulating driving up an incline. Turn the wheel to lock while doing this, if the CV is bad it will start clicking like mad.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  8. #8 Re: Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
    Mar 2017
    Internet
    On the steering feel of the jut. Have the steering rack to subframe bolts checked. Sometimes they like to loosen up and it'll allow all parts to seem good and yet give you a feeling. Although a mechanic looking at tie rods and ball joints would pick up on the issue.
    Couple of the things you mentioned have me wondering if you are going to the right guy for your car work. A second opinion may be in order.
  9. #9 Re: Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Quote Originally Posted by BillBooost37 View Post
    ^ I agree
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  10. #10 Re: Looking For Knowledge From My Fellow Grand Prix 'ers Front End Issue
    May 2016
    Burns City, Indiana
    CV check, go to large parking lot, turn wheel hard left ot right and do donuts. If it loose or cracked it should pop and crack. I dont get it, new axles are around $79 new each, you need to be able to separate lower ball joint, drive axle out and pop out from trans.
    Also another frontend noize you may hear from is subframe bolts loose or worn.
  1. 1963 Grand Prix Knowledge Requested
    By Dillon14 in forum General Grand Prix Discussion
    Last Post: 04-11-2016, 05:30 PM
  2. Hello Fellow Grand Prix GTP Owners!
    By Ronstershadetree in forum Introductions/Noob Questions
    Last Post: 07-27-2013, 10:48 AM
  3. HELLO ! ! ! my fellow Grand Prix owners : )
    By polecar13 in forum Introductions/Noob Questions
    Last Post: 08-05-2012, 12:15 AM
  4. what going on fellow grand prix drivers....
    By Paulrod84 in forum Introductions/Noob Questions
    Last Post: 12-05-2011, 03:33 PM
  5. Hello fellow grand prix enthusiasts
    By MuscleCarLvrV8 in forum Introductions/Noob Questions
    Last Post: 07-23-2009, 06:18 AM
