Thread: How long/ what does it take to heat soak a intercooled set up?
Results 1 to 17 of 17
  1. #1 How long/ what does it take to heat soak a intercooled set up?
    Apr 2017
    Ontario
    SS intercooler/stage 2 or any inter cooler set up.
    How long does it take for it to get heat soaked and not work very well? What do you (as the driver) need to do in order to make the car so hot that the intercooler doesn't preform good.
    Thoughts?
    99 GTP: DIY FWI-3in CDP-rez del-plog-napa spark wires COME ON WILL I WANT MY TUNE!!!!!!<3 Intercooling next
    <3 PROUDLY Canadian / PROUDLY Austrian "Look, Gasoline's perfectly safe.....until you introduce ol Orange."
  2. #2 Re: How long/ what does it take to heat soak a intercooled set up?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    It can take anywhere from hours to minutes, it all depends on how hard you drive. Beat on it like a red headed step child, or go to the drag strip, and it'll get hot quick.
    Some have gotten ingenious, putting the heat exchanger in the trunk inside an ice bath, or using the A/C core as a chiller in front of the heat exchanger... All requiring a whole bunch of extra work and time, introduces potential problems, and makes using the car as a daily driver impossible or impractical.
    It's all up to what you're doing to the car, with the car, and how much you're willing to spend.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: How long/ what does it take to heat soak a intercooled set up?
    Mar 2017
    Internet
    Who says it has to heat soak?
    Do you have sufficient heat exchanger and enough coolant capacity?
  4. #4 Re: How long/ what does it take to heat soak a intercooled set up?
    Oct 2014
    Frederick, MD
    My thoughts are: if he's worried about heat soak, then most likely he's either at the track, or trying too hard to make a w-body go fast.
    If it's just a daily driver that one would want to make whine like crazy with a tiny pulley, just for the giggles, then heat soak isn't an issue one would think about.
  5. #5 Re: How long/ what does it take to heat soak a intercooled set up?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    a standard short stack intercooler with the core and a Scirocco-type FMHE will heat soak in a 1/4 mile pass or about 15 seconds at WOT on the street and take about 10 minutes of recirculation to cool back down (my experience at the track - YMMV). The core will transfer heat pretty well, but the key to a SSIC is capacity -- you need a big FMHE, reservoir, and a good pump to get good recovery out of it.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: How long/ what does it take to heat soak a intercooled set up?
    Kemmerer, Wyoming
    when I had my intercooler on, I put the car on the dyno, and after a dozen pulls it still wasn't heat soaked. I basically had the car on the dyno for 6 hours and probably more than a dozen pulls and it never got heat soaked. full size phenolic intercooler with a frozen boost heat exchanger. I'm thinking about doing another intercooler, but this time instead of using antifreeze, I would use water and tie in an icebox reservoir in the trunk to get some extra cooling for the dragstrip.
  7. #7 Re: How long/ what does it take to heat soak a intercooled set up?
    Apr 2017
    Ontario
    I'm not racing the car, it's simply a daily driver that doesn't get WOT all the time, here and there but isn't getting anywhere close to racing temps. I think with constant flow of good air it won't heat soak but i'm just wondering how badly they get when used. I know everyone bad talks the SSIC set up and all but if it's daily driven i don't see how even the smallest IC can get so badly heat soaked it can't do any good.
  8. #8 Re: How long/ what does it take to heat soak a intercooled set up?
    Oct 2014
    Frederick, MD
    If you aren't racing or even going WOT very much, then a SSIC will do you just fine and probably won't ever heat soak.
    The only bad talking was before the w-body platform died, and everyone was still trying to go fast.
  9. #9 Re: How long/ what does it take to heat soak a intercooled set up?
    Apr 2017
    Ontario
    okay cool thanks! Yea i like them. wasn't ready to drop over 100 Canadian on a massive IC
    mine does go fast......
  10. #10 Re: How long/ what does it take to heat soak a intercooled set up?
    May 2008
    Schuyler, NE
    Quote Originally Posted by mguzzo View Post
    This. The ssic isn't bad as long as you stick some money into it. Well, besides the vacuum leak problems.
  11. #11 Re: How long/ what does it take to heat soak a intercooled set up?
    Apr 2017
    Ontario
    What exactly is an FMHE? is that a heat exchanger?
  12. #12 Re: How long/ what does it take to heat soak a intercooled set up?
    May 2008
    Schuyler, NE
    Front mount heat exchanger
  13. #13 Re: How long/ what does it take to heat soak a intercooled set up?
    Kemmerer, Wyoming
  14. #14 Re: How long/ what does it take to heat soak a intercooled set up?
    Apr 2017
    Ontario
    i think i'll go for the SSIC but all i heard was bad things, like you said it was before the whole car was dead, guess guys tried pushing them to hard.
  15. #15 Re: How long/ what does it take to heat soak a intercooled set up?
    Buffalo NY
    My experience was that the SSIC took away about 4 to 5 degrees of KR during a 1/4 mile run. This was on a mild 3.4 setup (3.4, front PLOG, SSIC, SR rockers, and 3" downpipe / catback plus tuning with an AFC). The car ran high 13's to 14 flat consistently. I didn't have a reservoir, just the SSIC and a Scirocco FMHE and some extra hose length.
    If you decide to install the SSIC, there is a problem with a stock gasket leaving a gap in the core that can create a vacuum leak under the snout. You need to cut some extra gasket material and fill in this area.
    you can PM me with any questions if you need help.
  16. #16 Re: How long/ what does it take to heat soak a intercooled set up?
    Apr 2017
    Ontario
    Thanks i defiantly will! intercooling is on the top of my list! so shouldn't be long now.
  17. #17 Re: How long/ what does it take to heat soak a intercooled set up?
    Buffalo NY
    where are you in ontario? I'm across the border in Buffalo. Maybe with a little planning, do a mod day when you're ready and id be able to lend a hand
  1. too much heat soak
    By 04gtpnoob in forum 04+ Specifics
    Last Post: 03-19-2016, 06:01 PM
  2. 436 WHP non-intercooled Gen 3 E85 with XP Cam
    By BoostedPontiac in forum Track Sessions and Kills
    Last Post: 02-18-2016, 09:45 AM
  3. Intercooled vs. e85
    By hensleya1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2014, 07:13 PM
  4. going intercooled
    By hollas13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2014, 10:59 PM
