Thread: How long/ what does it take to heat soak a intercooled set up?
Results 1 to 17 of 17
Threaded View
  1. #15 Re: How long/ what does it take to heat soak a intercooled set up?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    My experience was that the SSIC took away about 4 to 5 degrees of KR during a 1/4 mile run. This was on a mild 3.4 setup (3.4, front PLOG, SSIC, SR rockers, and 3" downpipe / catback plus tuning with an AFC). The car ran high 13's to 14 flat consistently. I didn't have a reservoir, just the SSIC and a Scirocco FMHE and some extra hose length.
    If you decide to install the SSIC, there is a problem with a stock gasket leaving a gap in the core that can create a vacuum leak under the snout. You need to cut some extra gasket material and fill in this area.
    you can PM me with any questions if you need help.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  1. too much heat soak
    By 04gtpnoob in forum 04+ Specifics
    Last Post: 03-19-2016, 06:01 PM
  2. 436 WHP non-intercooled Gen 3 E85 with XP Cam
    By BoostedPontiac in forum Track Sessions and Kills
    Last Post: 02-18-2016, 09:45 AM
  3. Intercooled vs. e85
    By hensleya1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2014, 07:13 PM
  4. going intercooled
    By hollas13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2014, 10:59 PM
