Thread: Nitrous kit or suspension??
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 85
  1. #1 Nitrous kit or suspension??
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys I have some money to blow and I'm torn on if I should spend it on a nitrous kit or do some suspension upgrades(maybe some new struts and ssc springs). What do you guys think!!?!
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: Nitrous kit or suspension??
    Neither.
  3. #3 Re: Nitrous kit or suspension??
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Why nitrous? Do you track your car? or specifically need it? Since riding around with nitrous connected is not legal in most states, I would go with suspension.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  4. #4 Re: Nitrous kit or suspension??
    Buffalo
    Nitrous !
  5. #5 Re: Nitrous kit or suspension??
    Oct 2015
    I don't track it very often and don't specifically need it. I live in Arizona and last time I checked it was illegal to have it hooked up but I kind of figured that law was like having hid in halogen housings (no cop cares). Plus why would a cop be searching my trunk in the first place.
  6. #6 Re: Nitrous kit or suspension??
    Sep 2015
    Cheyenne, WY
    Go for the suspension.
    The score is now 2-1 in early voting!
  7. #7 Re: Nitrous kit or suspension??
    Oct 2015
    Ya suspension is more practical anyway. I've just pretty much run out of performance mods unless I go cam or intercooler both of which are pretty expensive and time consuming. Nitrous just seemed like a reasonably priced, easy install gain.
  8. #8 Re: Nitrous kit or suspension??
    Buffalo
    Everyone has a suspension
  9. #9 Re: Nitrous kit or suspension??
    SE Level Member Keko's Avatar
    Nov 2016
    California
    Extra power is nice but it's almost always more rewarding to improve something that you can always use, like improved suspension.
    Then again I installed an intercooler before any suspension related parts...
    [Daily] 2002 GTP 40th Ann - FSIC, dp+plog, 3.3", ported LIM, HAI, front+rear sway bars, poly mounts, zzp tune for now :/
    [Fun] 2012 mazdaspeed3 - dp, 3" intake, FMIC, HPFP, Custom tune, lots of other goodies
  10. #10 Re: Nitrous kit or suspension??
    Oct 2015
    Ya speed is more fun but it's safer if and more practical if you can actually control the speed you make with a good suspension.
    Sub question: if I go suspension should i do some new gr2s and canuck springs
    Or addco rear/dorman front sway bars with poly bushing and endlinks.
    Which would grant more prerformance?
  11. #11 Re: Nitrous kit or suspension??
    May 2008
    Schuyler, NE
    Spray the piss out of it!
  12. #12 Re: Nitrous kit or suspension??
    Nov 2016
    California
    Last week I installed the progress front sway bar with poly endlinks, and I already had a GMPP rear sway bar in. It made a huge difference. The car actually corners flat now and at better speeds. I'm on stock suspension and I don't really see a need to improve it with how much the sway bars have helped. I also did replace both tie rods at the same time since the bushings in mine were obliterated. That probably helps a little too
  13. #13 Re: Nitrous kit or suspension??
    Oct 2015
    Quote Originally Posted by Keko View Post
    Hmm sway bars sound pretty nice and they are the cheapest upgrade out of my choices..
  14. #14 Re: Nitrous kit or suspension??
    Sep 2015
    Cheyenne, WY
    Suspension 3 - juice 2 !!!
  15. #15 Re: Nitrous kit or suspension??
    Oct 2015
    Ya I'm pretty decided on suspension. I'm still going to do nitrous unless I can find a shop that can do a cam install for a fair price. I've done all the work to my car so far but a cam is pretty intense sh*t. My backyard mechanic skills aren't at that level yet haha
  16. #16 Re: Nitrous kit or suspension??
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by suitercrew View Post
    Man up and do it yourself. The hardest part about a cam install are the valve springs if you're using an autozone or similar valve spring tool. They just suck, plain and simple. But the cam and all that is pretty straightforward.
    If you have enough money for a full nitrous setup including a tune and bottle refills, then you have plenty for a cam. DO THE CAM.
    No one here has ever regretted putting a decent cam in their car. (don't go VS btw, Go big or go home)
  17. #17 Re: Nitrous kit or suspension??
    Oct 2015
    Ya I have a tuner so I'm good on that. I already have 90# springs installed but I don't think that's heavy enough for any besides the vs which isn't worth the work. To top it off it's my daily driver. When I did my top swap it took me 3 days.
  18. #18 Re: Nitrous kit or suspension??
    Jan 2013
    Raleigh, NC
    Yeah the whole having your daily driver down for multiple days thing SUCKS. Good call on not having that. I'll stick with my suspension advice. Good luck.
  19. #19 Re: Nitrous kit or suspension??
    Buffalo
    I think it would still take a weekend for someone with a little mechanical experience to swap the suspension
    building all 4 struts. Removing old ones. Trailing arms , rear links. Front links. Sway bushings front and rear. Front end links. Lower control arms
  20. #20 Re: Nitrous kit or suspension??
    Oct 2015
    Quote Originally Posted by CrazyGuy03 View Post
    Your right but i can build the struts off the car and I can split it up. One week I can do all the front stuff and next week I can do all the rear ☺
  1. Nitrous?
    By Classy Pontiac in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2012, 11:05 AM
  2. Nitrous?
    By MoBoost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2011, 02:43 PM
  3. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
