Thread: Emergency Help!!! Front Hub Nut Spun off
Results 1 to 17 of 17
  1. #1 Emergency Help!!! Front Hub Nut Spun off
    SE Level Member sn95gt50's Avatar
    Jul 2008
    The front hub nut on the end of the axle spun off, luckily my son saw it. Heading to get a socket, can someone tell me the torque spec on that thing?
    Dealer just replaced the hub, got to get it back together to get it back to the dealer.
    Thanks!
    John
  2. #2 Re: Emergency Help!!! Front Hub Nut Spun off
    118ft lbs.
  3. #3 Re: Emergency Help!!! Front Hub Nut Spun off
    Buffalo
    Dont forget the the pin
  4. #4 Re: Emergency Help!!! Front Hub Nut Spun off
    There is no cotter pin holes on axle shafts, not on a 3800 axle that I've seen.
  5. #5 Re: Emergency Help!!! Front Hub Nut Spun off
    GTP Level Member
    Oct 2014
    ^^^^x2
  6. #6 Re: Emergency Help!!! Front Hub Nut Spun off
    Quote Originally Posted by CrazyGuy03 View Post
    What?
  7. #7 Re: Emergency Help!!! Front Hub Nut Spun off
    Jul 2008
    Glad I asked, I would not have thought that much, 118 it is. Yep, no cotter pin.
  8. #8 Re: Emergency Help!!! Front Hub Nut Spun off
    Jul 2008
    All back together, thanks for the quick replies, u guys rock.
    Sent from my SM-G930V using Tapatalk
  9. #9 Re: Emergency Help!!! Front Hub Nut Spun off
    Buffalo
    yall missed the perfect opportunity for some sarcasm ... lmao
  10. #10 Re: Emergency Help!!! Front Hub Nut Spun off
    hangover park IL
    ive seen the gamut of ~120-140ish ftlbs, seems to be whatever number they pulled out of a hat cause they all use the same bearing/outer tulip
    ~James~ Psychotic Gearhead
  11. #11 Re: Emergency Help!!! Front Hub Nut Spun off
    Jul 2010
    Coquitlam,BC,Canada
    Old specs were 150 or so, and current specs are 118 or so. I've used both, and bearings failed with both torque settings.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Emergency Help!!! Front Hub Nut Spun off
    If you used All-Data the only year that was ever 159 ft lbs was 2001 but 97-00 was 118 and same with 2002+. No idea why that is and this was 3-4 years ago when I still could use it. Even any of the other w-body and H-body cars that use the same bearings got either the same tq spec or a slightly different.
  13. #13 Re: Emergency Help!!! Front Hub Nut Spun off
    Jul 2010
    Coquitlam,BC,Canada
    Old AllData and my 2002GT.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Emergency Help!!! Front Hub Nut Spun off
    Here is a 2002 model year using the 2012+ version of the online all data.
  15. #15 Re: Emergency Help!!! Front Hub Nut Spun off
    Jul 2010
    Coquitlam,BC,Canada
    Was just saying there are two specs out there, which there are.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  16. #16 Re: Emergency Help!!! Front Hub Nut Spun off
    There shouldn't be if it's the same site used but it comes down to what version you are using.
    Mitchel has it at 118ft lbs. Chiltons and Haynes manuals I don't even bother looking at for specs, as they can differ so much. I don't torque anything down anyway unless it's a super important like head studs, internal engine parts, lug nuts. Everything else gets the brap brap with my impact gun or my perfected german torque spec.
  17. #17 Re: Emergency Help!!! Front Hub Nut Spun off
    hangover park IL
    much like setting up most bearings when new... I shoot for the high spec, when reassembling used I go for the low spec.
    Pinion bearings carrier bearings you name it
  1. Spun rod prevention
    By rockystar99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2016, 06:53 PM
  2. Spun rod bearing
    By mofford12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2013, 10:38 PM
  3. emergency please help!!!
    By asite57 in forum General Tech Discussion
    Last Post: 08-02-2012, 06:52 PM
  4. spun a bearing??!
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2012, 01:14 PM
  5. Spun a bearing
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 12:05 PM
