Having the same issue with my 06 only not quite as bad yet. Seems like it's becoming a common issue for 04+ cars as they age.Mine will turn high beams on any time the right hand turn signal is used after the sensor sees it's dark out. New or good used multi function switch is the fix from the research I've done. Pretty sure there is an open recall for 07 cars for the headlight module aswell.
