Thread: Still having KR issues
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Still having KR issues
    is that neg or pos at cruise and idle?
    its not super horrible either way. seen worse zzp tunes.
  2. #22 Re: Still having KR issues
    Kemmerer, Wyoming
    Quote Originally Posted by khornocker View Post
    what I'm doing is when I pull out onto the highway I'm flooring it to WOT and holding it till around 100 mph. I live way out in the country so traffic isn't an issue. once it get to the interstate i set my cruise control to 72 mph and my fuel trim was at 1.56.
    At idle stopped at a red light my fuel trim is 12.5
    ill have to use my paddle shifter to keep it in 3rd but I don't even think I need to since its rich way before it shifts into 4th. im going to baby the car for a bit till I can get this issue figured out. I'm really hoping with everybody's here we can resolve this.
    just to clarify, did you mean to say +12.5 or -12.5. does your car have the option to shift into 3rd gear with the shifter? just do that instead. having your fuel trim at 1.56 is good.
  3. #23 Re: Still having KR issues
    SE Level Member khornocker's Avatar
    Jan 2016
    Corydon, Indiana
    I meant +1.56 at cruise and +12.5 at idle.
    since my car is the Comp G the shifter only has "D" and "M" (to activate the sheering wheel paddle shifters)
  4. #24 Re: Still having KR issues
    idle is lean, real lean, or theres a vac leak.
    is your pcm stock still? or it a canned tune?
  5. #25 Re: Still having KR issues
    Jan 2016
    Corydon, Indiana
    its a canned tune from Overkill.
    ill look far a vacuum leak when I get home today. it still idles smooth though
  6. #26 Re: Still having KR issues
    a small leak can make it go pos, a large one will make it +16. real large and it will surge at idle.
  7. #27 Re: Still having KR issues
    Jan 2016
    Corydon, Indiana
    I looked at my vacuum lines last night and didn't find anything that really stood out as being bad. I did replace a dry rotted line that goes to the SC by-pass actuator but that didn't make a difference with my fuel trims this morning. ill check the line going to the fuel pressure regulator next but I have to wait for the rain to stop.
  1. AC Issues
    By Kaiser Pontiac in forum General Tech Discussion
    Last Post: 10-26-2015, 09:47 PM
  2. kr issues
    By jrb1027 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2013, 08:03 PM
  3. A/C Issues
    By SuperSE in forum General Tech Discussion
    Last Post: 05-23-2013, 08:45 PM
  4. MAF Issues?
    By Jevik in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2013, 04:21 PM
  5. A/C Issues
    By ReaperRob in forum General Tech Discussion
    Last Post: 08-10-2009, 09:55 PM
