Thread: service warnings all at one time
Results 1 to 8 of 8
  1. #1 service warnings all at one time
    May 2016
    Sacramento CA
    I have an 04 GTP. It has only 54000 orig miles but the other day all service lights came on at the same time. Service brake system, service traction, service power steering. Any ideas what is causing all these to error at once.
  2. #2 Re: service warnings all at one time
    Some sort of wiring issue is my guess.
    Clean all known battery contacts and grounds and see if they come back.
  3. #3 Re: service warnings all at one time
    seems abs related to me. get the car scanned at a shop for abs codes.
  4. #4 Re: service warnings all at one time
    GXP Level Member
    Mar 2015
    Tomball
    Did you get a reduced engine power as well?
  5. #5 Re: service warnings all at one time
    hangover park IL
    this is sometimes a harbinger of charging system/voltage issues as the car shuts down systems to save power. but its also quite common with a wheel speed sensor hard failure
    ~James~ Psychotic Gearhead
  6. #6 Re: service warnings all at one time
    May 2016
    Meriden,Ct
    I'm getting a service vehicle up to 5 times a day recently,along with a occasional charging system failure.I noticed yesterday I had car in park and tried reving it the throttle response was super delayed and not nearly as powerfull a rev as it should of been.Starting to think it is causing a issue with the throttle response.I pulled a U0073 communication bus off code in save folder.Any ideas??No chk engine lights,just super annoying.
  7. #7 Re: service warnings all at one time
    Yoga city
    u code is a communication, I never had a check engine the whole time I had issues. Ended up being a ebcm and a faulty wire. but bad charging system I.E. alt, battery or even the amp clamp that's inline with the negative post. Your u code points towards the loss of bcm communication. could be a wire or bad bcm also. I would start to eliminate anything.
  8. #8 Re: service warnings all at one time
    GXP Level Member
    Mar 2015
    Tomball
    Aftermarket radio too I guess?
  1. ABS Service, Traction Control Service & variable effort steering.
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 06-10-2017, 08:43 PM
  2. Replies: 5
    Last Post: 02-01-2017, 09:35 PM
  3. 3 Warnings just popped up
    By mcbassin in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2015, 11:16 AM
  4. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
