Thread: '99 GT weird problems
Results 1 to 5 of 5
  1. #1 '99 GT weird problems
    May 2016
    northern IL
    Hello, new member here, have a '99 GT. Every day when when I drive it the engine will stumble for a split second and the the "trac off" light will come on and the tach goes dead, can't see anything else not working, also when it does this engine runs but will knock and ping if I accelerate. Also if I'm idling at a light when this happens the engine will stall. Stays this way until I shut it off, then when I restart, everything is back to normal, tach works, 'trac' light goes out, engine doesn't knock. Could this be a ECM problem? seems like unrelated symptoms.
    Thanks
  2. #2 Re: '99 GT weird problems
    Is your check engine light on at all?
  3. #3 Re: '99 GT weird problems
    sounds like a crank sensor and a separate abs issue.
  4. #4 Re: '99 GT weird problems
    May 2016
    northern IL
    Check engine light is on, can't remember what the code is, I might go check it again.
  5. #5 Re: '99 GT weird problems
    Quote Originally Posted by farmerchad View Post
    The code/codes would be helpful. And I agree with Scott the tach dropping to zero is usually a sign of the crank sensor going bad.
  1. 2005 gtp weird problems
    By BigwhiteGTP in forum General Tech Discussion
    Last Post: 08-28-2013, 06:29 PM
  2. weird problems hellp please
    By imdaman3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-01-2010, 10:08 PM
  3. Weird radiator problems...
    By CSteen85 in forum General Tech Discussion
    Last Post: 03-24-2010, 02:37 PM
  4. Weird problems
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2008, 08:21 PM
  5. Weird shifting problems
    By Sick03L in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2008, 07:48 PM
