Thread: 16 Inch Rim Options
Results 1 to 15 of 15
  1. #1 16 Inch Rim Options
    SE Level Member themantis's Avatar
    Mar 2016
    Not planning to upgrade anytime soon, but what are my options for selecting an aesthetically pleasing set of rims without increasing unsprung weight or changing stock dimensions --> (225/60 R16 98T tires just put on)
  2. #2 Re: 16 Inch Rim Options
    Push to Open GTPkirmet's Avatar
    Sep 2015
    Spokane
    Quote Originally Posted by themantis View Post
    Pre-gens dude! they looks sweet on the 97-03 wbodies
    I would give photo credit but im unsure of the owner, hopefully he doesn't mind.
    98 GP Build?: http://www.grandprixforums.net/threa...-in-particular
    Power :Gen V, 3.6, 10.5mm, HS 1.9s, 105#, SDs, FWI, DHP Tuned, CS144
    Stuff :Gauges, 04 Leather seats, Cool stereo, Pregens, LEDs, Retros
  3. #3 Re: 16 Inch Rim Options
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Id also say pregens. I had them for a while a long time ago.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  4. #4 Re: 16 Inch Rim Options
    hangover park IL
    *1st gen W
    iirc tq stars are some of the lightest oem wheels for the 2nd gen, lighter than the 1st gen "pontiac 5 spoke"
    ~James~ Psychotic Gearhead
  5. #5 Re: 16 Inch Rim Options
    I've had both T-stars and pre-gen rims on my old car. I think I weighed them both and T-stars were around 16-18lbs and the pre-gens were maybe 1 lb more because of the thicker spokes. I have a spare pre-gen rim in the garage but I'm too lazy to go weigh it again.
  6. #6 Re: 16 Inch Rim Options
    Sep 2015
    Spokane
    Quote Originally Posted by Silver2kgtp View Post
    I like seeing color matched pregens, very nice ride man.
  7. #7 Re: 16 Inch Rim Options
    Since everyone likes to whore out their pictures lol, I will join in to show a 4 door.
  8. #8 Re: 16 Inch Rim Options
    Pregens on my bronze coupe
    http://www.thechicagogarage.com/foru...go-here-8.html
    On dem mickey Thompson drag radials too.
  9. #9 Re: 16 Inch Rim Options
    Mar 2016
    I couldn't exactly color match... 😂 but I'm proud to have avoided rim rash after 17 years. Stock matches well, but thanks for advising pregen. Do companies like BBS, Konig, Work, Enkei etc. have any options?
  10. #10 Re: 16 Inch Rim Options
    Sep 2015
    Spokane
    What size tire are you running?
  11. #11 Re: 16 Inch Rim Options
    The factory 225/60/16 size.
    Those were Cooper CS4's, a now discontinued tire option. They seemed to be a wider 225 option if that makes sense, not all 225's are "exactly" the same and don't all look the same on every rim.
  12. #12 Re: 16 Inch Rim Options
    Feb 2008
    NY
    Quote Originally Posted by GTPkirmet View Post
    THX!!!
  13. #13 Re: 16 Inch Rim Options
    Sep 2015
    Spokane
    Welcome sir. And to answer your original question, either stick with you tstars or go with pregens if you want to stick with 16s, otherwise any after market wheel wouldn't look quite right with all that rubber on it. Go with a 17 or 18" wheel if you want aftermarket.
  14. #14 Re: 16 Inch Rim Options
    SE Level Member 01grandpri's Avatar
    Oct 2015
    allendale michigan
  15. #15 Re: 16 Inch Rim Options
    Oct 2015
    allendale michigan
    Pregens are the way to go! I went with a 245/50/16 gives it I nice stance😀
  1. do i new a 3 inch dp
    By gpgt2002 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2010, 11:45 PM
  2. flanging from 2.5 inch downpipe to 3 inch exhaust?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 07:44 PM
  3. 20 inch rim help
    By mzendano in forum Tires & Wheels
    Last Post: 01-10-2009, 02:48 PM
