Thread: Need help fast!
Results 1 to 20 of 21
  1. #1 Need help fast!
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Car drove fine on the way to work 20 min on freeway, car was sitting in son all 11 hours of my shift. Started it up put it in drive, gave it gas. Nothing.... Wtf put it in 3rd nothing.... Put in 2nd felt a jolt, Starred to pull off it was slow n sputtered, got up to speed, and can manually shift into 3rd n drive.... Only have 116k miles n no issues before this.... I'm confused....
    99 GTP, F1 Hood,CAI,HP TUNE,RoofRails,HID,Front/Rear STB,
  2. #2 Re: Need help fast!
    SWPA
    I've read this too many times here. Probably broke forward band. It goes at random times.
  3. #3 Re: Need help fast!
    Yup..forward band. which..is the second piece that goes into a trans during a fresh build
  4. #4 Re: Need help fast!
    Sep 2015
    Seattle
    What's the price on that typically? Just called a local shop they said 3-3500k
  5. #5 Re: Need help fast!
    they are going to whack you to pull the trans, then disassemble, fix the band...maybe rebuild the rest while it's out and then drop it back in. I've seen it around $1200-$3500.
    not sure what you should pay, I learned how to fix the problem on my own and heck..my labor is cheap.
  6. #6 Re: Need help fast!
    Sep 2015
    Seattle
    I checked the fluid as well it's a lil bit of a light brown. Worth even dropping the pan for filter n fluid change at this point? I can manually shift from 123D. Starting in 1 of course. Thanks
  7. #7 Re: Need help fast!
    The band is broken. You can confirm it for us once you drop the pan. But in reality the only one that is semi hopeful that it isn't is you. That's not a knock.. it's just the truth.. we have seen so many, it's a given.
    Sorry. A used trans would probably cost less than rebuilding, but again you take a chance
  8. #8 Re: Need help fast!
    Sep 2015
    Seattle
    Thanks for everything bill. Appreciate it!
  9. #9 Re: Need help fast!
    Sep 2015
    Seattle
    Thinking about taking it over to the Eastside of the state where my family is. As my grandpa use to run his own car lot and has a few connections. Should I tow it there or drive it? Can it cause anymore harm? Thanks
  10. #10 Re: Need help fast!
    it cant get any worse then it is now. the whole tranny needs to come apart to fix that band, why most people will just get a rebuild.
    some shops are pretty shady, they fix whats broken and call it rebuilt, if your paying 1800 plus make sure they install new clutch packs and common electronic parts that fail seals and such.
  11. #11 Re: Need help fast!
    Sep 2015
    Seattle
    Thanks. Yeah that's what I figured. Will be nice to have a rebuilt trans. Esp since the car is well taken care of and I don't plan to sell anytime soon either. Thanks
  12. #12 Re: Need help fast!
    Sep 2015
    Seattle
    There is one in the FS section ironically... Should I pass it up since the electronics aren't new?
  13. #13 Re: Need help fast!
    that brandon guy is pretty solid, not the first tranny hes rebuilt and sold.
  14. #14 Re: Need help fast!
    I'd trust Brandon to build a trans, he's a good guy. Well known and willing to help/teach others through how to threads like I am. Therefore I'd back him. Heck, a few of the tools he's using to build transmissions, he bought from me. Some would think that makes the transmission better somehow. lol
  15. #15 Re: Need help fast!
    Sep 2015
    Seattle
    I was able to get it scheduled and done from a shop my grandpa has used for years for 18-2200. With 1 year warranty. Anything helpful I can have him add while he's doing the full rebuild. Transgo shift kit?
  16. #16 Re: Need help fast!
    Did you check out tep ? Full rebuild last I checked was way cheaper then what you've been quoted or just buy Brandons trans
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  17. #17 Re: Need help fast!
    1600 is the cheap one at tep, but thats not including labor to swap it.
  18. #18 Re: Need help fast!
    Labor is free if you do it yourself! I wouldn't just jump the gun and spend that kind of money at just any shop because that's who grandpa uses.
    04 Comp G.
  19. #19 Re: Need help fast!
    Ensure they are replacing all clutches and steels, that they will clearance the clutch packs and not just toss in the correct number of each per the GM book. You'll want a hardened 4th clutch hub shaft and a replacement EPS aka pressure soleniod.
  20. #20 Re: Need help fast!
    Sep 2015
    Seattle
    Ok thanks. Also i looked into TEP hps1 its a lot more then what the website tells you. Almost 2k just for tranny then ship is 195 plus core fee and you either ship your orig tranny again for 195, or just take their core and you don't get a slip to ship your orig back for free then either install yourself you're sutting around 2500, or a shop then you're well over 3k. Not as cheap as it appears...
  1. How fast do people consider "fast"?
    By Lowdown112 in forum General Grand Prix Discussion
    Last Post: 01-23-2013, 06:23 AM
  2. That is a fast Grand Prix, I don't think they were meant to go that fast
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 07-04-2011, 11:32 AM
  3. help fast
    By gtcoup in forum General Tech Discussion
    Last Post: 02-17-2011, 03:28 PM
  4. How fast have you had your GTP?
    By a3gtp in forum General Tech Discussion
    Last Post: 06-10-2009, 10:03 PM
  5. Need help FAST
    By probuilder1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-02-2009, 08:35 PM
