Thread: Started Yesterday, won't start today
Results 1 to 5 of 5
  1. #1 Started Yesterday, won't start today
    Sep 2012
    Brooksville, FL
    Ok, Strange thing goinng on here. 2000 GTP Daytona, was starting fine for the past 3 years i've owned it. literally would start as soon as it started cranking. Drove the car home from work, parked it in the driveway as normal. went out to go to work the next morning & it just kept cranking. got a ride to work, came home & it started right up as if nothing was wrong. it was fine for 3 weeks & then it would not start again while i was leaving work. left the car at work for 3 days (tried starting it each day & nothing) then on the 4th day i tried again on my way out & it started as if nothing was wrong again. got it home, & it started every day for 4 days. I thought maybe the fuel pump was going out. changed that, started right up on Sunday, went out to go to work this morning & nothing, just kept cranking again. I have done the typical tune up (plugs, wires, fuel filter, oil change). Any ideas or direction to start looking would be appreciated.
  2. #2 Re: Started Yesterday, won't start today
    SWPA
    Try some diagnostics before throwing parts at it.
    You need to check for spark and fuel when it is not starting. Just because it has a new fuel pump doesn't mean the injectors are firing. Just because it has new plugs and wires doesn't mean it has spark.
  3. #3 Re: Started Yesterday, won't start today
    Fire it up.. tap with your finger on the top of the maf sensor. If it flutters, sputters or dies.. it's a maf.
    IDK.. it feels right.
  4. #4 Re: Started Yesterday, won't start today
    GTP Level Member
    Oct 2014
    Wiggle the wires from the ignition control module when in a no start situation. It may start. I had very similar symptoms and it was a bad ICM
    Sent from my iPad using Tapatalk
  5. #5 Re: Started Yesterday, won't start today
    Sep 2012
    Brooksville, FL
    Looks like you may have been right w/ the ICM. the screw that holds the wire harness into the ICM was loose. have not had an issue since I tightened it down.
  1. A new noise started today
    By Kolton Lock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 01:36 PM
  2. New fuel filter today and now car wont start/stay started
    By spider4 in forum General Tech Discussion
    Last Post: 01-04-2012, 10:50 AM
  3. my car started giving me troble today Help please
    By grandprixxx94 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-28-2011, 09:39 PM
  4. started SSAC install today...
    By benblank in forum 04+ Specifics
    Last Post: 04-17-2010, 07:57 PM
  5. Working fine yesterday, white smoke today
    By Panzer4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2009, 07:30 PM
