Thread: hard to fill up gas tank and P0446 code
Results 1 to 13 of 13
  1. #1 hard to fill up gas tank and P0446 code
    SE Level Member khornocker's Avatar
    Jan 2016
    Corydon, Indiana
    hello, I've searched the forum a bit but still need some help.
    when I bought my 2005 GTP a short while ago I noticed that its very hard to fill up the gas tank. the pump will shut off after a few seconds. the check engine light also came on with a P0446 Evap code. I already replaced the Vapor canister vent solenoid and that didn't fix my issue. im getting 12 volts with the key on at the vent solenoid wire harness, and when I apply 12 volts to the solenoid using a battery I can hear it open and close. however, once I plug the solenoid into the wire harness it does not open or close. could this be a pressure sensor?
    I was hoping I could find a vent hose that might be clogged but I cant find one. please help.
  2. #2 Re: hard to fill up gas tank and P0446 code
    did you take the canister off and see if its got gas inside it? they fail too, or a busted vent line tank to gas filler neck. that line rotted through on my car and it would click the pump off if the car was running, but filled fine car off. odd one for sure.
  3. #3 Re: hard to fill up gas tank and P0446 code
    Jan 2016
    Corydon, Indiana
    I have not removed the canister. I think its located on top of the fuel tank right? I have not checked anything else, ive been waiting for some warm and dry weather
  4. #4 Re: hard to fill up gas tank and P0446 code
    its under the filler neck in the quarter panel. where the vent solenoid is you said you changed.
    or you change the purge solenoid under the hood?
  5. #5 Re: hard to fill up gas tank and P0446 code
    Jan 2016
    Corydon, Indiana
    Oh. That also got changed. I was thinking of the charcoal canister
  6. #6 Re: hard to fill up gas tank and P0446 code
    thats the black tank under the vent solenoid. un bolt it take it out, see if its full of gas.
  7. #7 Re: hard to fill up gas tank and P0446 code
    Jan 2016
    Corydon, Indiana
    I checked a bit ago. It's dry. Doesn't even smell like gas fumes.
  8. #8 Re: hard to fill up gas tank and P0446 code
    and you changed the vent solenoid a top the canister?
  9. #9 Re: hard to fill up gas tank and P0446 code
    Jan 2016
    Corydon, Indiana
    Yes I changed both. For some reason the solenoid doesn't open once installed. I can't hear it open or close when the key is turned off and on.
  10. #10 Re: hard to fill up gas tank and P0446 code
    Apr 2016
    Decatur, IL
    Quote Originally Posted by khornocker View Post
    Have you tried to see if power is going to it by any chance?
  11. #11 Re: hard to fill up gas tank and P0446 code
    Jan 2016
    Corydon, Indiana
    Quote Originally Posted by Zstrode2939 View Post
    Yes I'm getting 12 volts with the key on
  12. #12 Re: hard to fill up gas tank and P0446 code
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I have the same issue with mine. I even fully removed the canister in the rear wheel well so the tube going to it was just open to the air and the car still will not take fuel unless put in very slowly. Except sometimes when it decides to take half a tank how its supposed to and then starts the stupid crap again. I just figured something was clogged in the tube and gave up
    I went NA when a whore left -$300 in my bank account.
  13. #13 Re: hard to fill up gas tank and P0446 code
    Jan 2016
    Corydon, Indiana
    hello. I have an update on my hard to fill gas tank issue...................its fixed!!!!!
    it was the charcoal canister. this morning I dropped the gas tank and installed a new canister and whammy! I can now fill up my gas tank without cussing every 2 seconds.
  1. cant fill up tank
    By prix04gt in forum 04+ Specifics
    Last Post: 01-17-2016, 12:08 AM
  2. 4T65E Code P1811, hard shifting, along with stalling at idle...
    By 2002GrandPrixGT40th in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2014, 05:30 PM
  3. code P0446
    By vagk1234 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-01-2013, 10:08 PM
  4. Gas Tank Hard to Fill
    By jeffconnors in forum General Tech Discussion
    Last Post: 11-06-2012, 06:28 PM
  5. tranny shifting hard. code po730 came up
    By tazgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-13-2011, 06:31 PM
