Thread: MAF Sensor problem
Results 1 to 9 of 9
  1. #1 MAF Sensor problem
    Oct 2012
    Ipperwash Ontario
    Hi I traced all the wires from the MAF sensor to the PCM and there are no breaks. The problem is that I don't get 12 volts to my MAF sensor there for engine light
  2. #2 Re: MAF Sensor problem
    St. Louis
    Have you checked the fuses?
  3. #3 Re: MAF Sensor problem
    under the hood box #22 iirc, marked ING.
  4. #4 Re: MAF Sensor problem
    Donating Users moddman's Avatar
    Midwest
    Might be the ignition switch is bad or a short in the ignition wiring someplace.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  5. #5 Re: MAF Sensor problem
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Check battery connection have good ground
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  6. #6 Re: MAF Sensor problem
    Oct 2012
    Ipperwash Ontario
    Thank you all it was fuse #21 codes are gone
  7. #7 Re: MAF Sensor problem
    220, 221, what ever it takes........old ass movie quote. lol good to hear.
  8. #8 Re: MAF Sensor problem
    I break stuff selliott's Avatar
    Kansas City
    Mr mom.....classic flick
  9. #9 Re: MAF Sensor problem
    where's mom keep the vacuum? you mean JAWS??????????
  1. MAF Sensor problem?
    By PrixGuy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2014, 06:31 AM
  2. New MAF Sensor - Problem
    By kamposs in forum General Tech Discussion
    Last Post: 12-31-2013, 07:54 PM
  3. MAF sensor problem?
    By 2000 Grand Prix GT Blue in forum General Tech Discussion
    Last Post: 06-03-2013, 08:26 PM
  4. MAF sensor problem
    By GTP Chic in forum General Tech Discussion
    Last Post: 05-07-2013, 02:41 AM
  5. Do I have an O2 sensor problem?
    By ronmexico in forum General Tech Discussion
    Last Post: 04-13-2012, 09:41 AM
