Thread: Transmission Problem not sure what it is
Results 1 to 14 of 14
  1. #1 Transmission Problem not sure what it is
    Mar 2016
    Hi guys! I'm new to this forum, I joined because my car won't move and I wanted input from other people that know what they are talking about, anyway I have a 2000 Grand Prix SE with 284k on the drive train.
    one day I floored it and when the tranny shifted down it totally missed the gear and redlined, now I have no gears, I rolled it home and I went underneath and listened and right where the trans is connected to the axle there is a huge rattle, and it obviously gets more aggressive if I rev it up. Maybe it's the front axle? can someone help me diagnose this?
  2. #2 Re: Transmission Problem not sure what it is
    If you have no movement even when you put it in manual first gear, either the pump is dead or the input shaft may have snapped.
    Just two very possible issues.
  3. #3 Re: Transmission Problem not sure what it is
    its blowed up sir!!!!
  4. #4 Re: Transmission Problem not sure what it is
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    It's shot. Time go to jy or pick n pull and pull one.
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  5. #5 Re: Transmission Problem not sure what it is
    Mar 2016
    Quote Originally Posted by Travisgt2 View Post
    how much do you think it'll cost in labor though cause I sure as heck can't replace a tranny on my own
  6. #6 Re: Transmission Problem not sure what it is
    most shops charge around 500 or so to swap a tranny. having a shop rebuild it tends to start at 1800 and only go up from there.
  7. #7 Re: Transmission Problem not sure what it is
    Mar 2016
    the cars only worth 900. kinda sounds totalled to me. thanks guys!
  8. #8 Re: Transmission Problem not sure what it is
    Mar 2014
    Tucson
    Flexplate?
  9. #9 Re: Transmission Problem not sure what it is
    where you live? there maybe a local willing to help out at cut rate prices. trans swap can be done in your drive ways, if the flex busted that also can be done in the driveway.
  10. #10 Re: Transmission Problem not sure what it is
    Mar 2016
    Kansas city area
  11. #11 Re: Transmission Problem not sure what it is
    http://www.grandprixforums.net/threa...ck-in-Business!! give these guys a shout. they know what they are doing.
  12. #12 Re: Transmission Problem not sure what it is
    Jan 2013
    leavenworth ks
    Those two guys are amazing. There's quite a few of us from kc area. They can definitely help!
  13. #13 Re: Transmission Problem not sure what it is
    Mar 2016
    so what would be the process in replacing the flex plate?
  14. #14 Re: Transmission Problem not sure what it is
    Remove the engine or transmission.
  1. Transmission problem
    By r3dr4ng3r95 in forum General Grand Prix Discussion
    Last Post: 04-20-2016, 10:38 PM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. Transmission Problem
    By rubent in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-14-2011, 10:34 AM
  4. transmission problem
    By jsucci in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2011, 04:59 PM
  5. Transmission problem(s)
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2009, 06:34 PM
