Thread: My project of swapping without much for tools or a garage...
Results 1 to 20 of 21
  1. #1 My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
    Loaned some of my tools out, so I'm stuck wrenching everything. This will be just a straight swap from totaled gtp to gt. Subfram and all going in 2000 gt. Hope all works out good for me, I need another car lol...
    Sent from my SM-N900T using Tapatalk
  2. #2 Re: My project of swapping without much for tools or a garage...
    London Ont, Canada
    thread moved out of Free For all.
  3. #3 Re: My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
    Sorry, where should it have been placed?
  4. #4 Re: My project of swapping without much for tools or a garage...
    Doesn't matter no one else posts anything in the right section anyway.
  5. #5 Re: My project of swapping without much for tools or a garage...
    Lmao well that's one way of doing it
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  6. #6 Re: My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
  7. #7 Re: My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
    https://vimeo.com/160682632
    This has been one hell of an ordeal for me. I did get it to stay running but without going through and working the wiring, I'm going to have some problems. Internal wiring is not set up the same and is throwing everything off. Dummy lights on and temp gauge won't work. The abs was the same but I got tat worked in today. Anyone have any ideas that might help?
    Thanks
  8. #8 Re: My project of swapping without much for tools or a garage...
    you need the gtp pcm in the gt car now, the map sensor pig tail cut off the old gtp harness, then cut the na map plug off and solder on the l67 map plug and vac line that in there.
    your missing the bbv solenoid pig tail too, thats gonna set a code. but can be tuned out with a tuner. iirc you can wire that in if you want. you got the old harness should be able to trace it down to the pcm.
  9. #9 Re: My project of swapping without much for tools or a garage...
    Kemmerer, Wyoming
    if you just get an 04+ map sensor from a supercharged car, it will plug right in
  10. #10 Re: My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
    I used the whole harness from the gtp and fuse box
  11. #11 Re: My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
    It's not matching with the internal wiring
  12. #12 Re: My project of swapping without much for tools or a garage...
    smart move. so what codes you get or whats it doing?
    the air box from the gt will fit too, its a better set up then the crappy 98 box you got in there.
  13. #13 Re: My project of swapping without much for tools or a garage...
    Quote Originally Posted by jamesk View Post
    put the other harness back in, only thing you need to change is the map pig tail, and add the bbs in or not. the pcm will still fit. if any sensors dont plug in, change swap the sensor from the na engine.
  14. #14 Re: My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
    I used the air box from the 98 but that's an easy switch. I can't get codes yet because I don't have the tool for it. Too much for me to even rent. Right now I'm just concerned about the temp gauge not working.
  15. #15 Re: My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
    Lol, I was already into making my own harness for it
  16. #16 Re: My project of swapping without much for tools or a garage...
    your mixing years that are not fully compatible. maybe best to run the na harness in its intact state. if the temp sensor plug is not the same, use the one from the na engine.
  17. #17 Re: My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
    How bout if I keep the 98 harness and just change the wiring going into the fuse box from the 2k?
  18. #18 Re: My project of swapping without much for tools or a garage...
    i see spaghetti all over the place.
    you should have left the na harness alone. added the l67 map and been done with it.
    guys top swap and dont change the harness, just add the one pig tail for the new map.
  19. #19 Re: My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
    I wouldn't be so persistent about the 98 wiring setup but I didn't do to well with the 2k wiring....
  20. #20 Re: My project of swapping without much for tools or a garage...
    Nov 2015
    missouri
    I did a full was and was told it's best to switch the wires and fuse box but I see that's not all right
  1. Replies: 97
    Last Post: 08-08-2017, 08:12 AM
  2. WTB: Tools
    By gtpeddie in forum Buy/Sell Other/Misc
    Last Post: 11-05-2016, 08:46 PM
  3. What tools to keep in my car?
    By acidcrashdburnd in forum General Tech Discussion
    Last Post: 07-06-2012, 05:22 AM
  4. New tools :-D
    By apierce1289 in forum General Grand Prix Discussion
    Last Post: 04-28-2012, 10:52 PM
  5. let's buy tools
    By Poil336 in forum Off Topic Discussion
    Last Post: 04-22-2011, 09:25 AM
