Thread: Gtp lo boost
Results 1 to 12 of 12
  1. #1 Gtp lo boost
    Mar 2015
    kankakee
    I have an 01 gtp and have a ported supercharger, 3.6 pulley, tog headers, zzp 3.0 downpipe, Flowmaster exhaust, intake, 1.0 pcm and I am pushing full boost on my d.i.c but on my gauge I am only reaching around 5-7psi I'm am under the impression the 97-03 model gtps stock have 8 psi stock, I changed my boost bypass valve, and vacuum lines and nothing changed any ideas?
    Sent from my SM-G900V using Tapatalk
  2. #2 Re: Gtp lo boost
    GXP Level Member
    Mar 2015
    Tomball
    Who ported the supercharger? And what does it look like? Could be that it's such a poor porting job that it's just that bad. And a downpipe and headers??
  3. #3 Re: Gtp lo boost
    Kemmerer, Wyoming
    your car is far from stock, I would be happy with the 5-7 lbs of boost with those mods. my car has an xp cam, ported L32 heads, headers, a stock gen 3 with a stock pulley and hasn't made more than 4 lbs of boost in some time. any time you increase airflow or increase exhaust flow, your boost pressure goes down.
  4. #4 Re: Gtp lo boost
    Mar 2015
    kankakee
    Quote Originally Posted by J57ltr View Post
    Zzp ported the supercharger
  5. #5 Re: Gtp lo boost
    Mar 2015
    kankakee
    Quote Originally Posted by SgtMarshal View Post
    Thanks for the reply and I didn't take that into account
  6. #6 Re: Gtp lo boost
    All boost is...is a measurement of restriction.
    The less boost, the less restriction the motor has.
    Just because you make 5, and the guy next to you makes 10, doesn't mean he is going to faster or make more power.
    Timing & AFR in these cars > High Boost levels (especially on GenIII blower cars that are horribly inefficient).
    You'll learn eventually.
  7. #7 Re: Gtp lo boost
    Kemmerer, Wyoming
    all a turbo or supercharger does is increase the pressure inside the engine, so the air of the atmosphere can fill the void created by the pressure. anything that increases the exhaust flow out of the engine will reduce the boost pressure.
  8. #8 Re: Gtp lo boost
    Mar 2015
    kankakee
    Quote Originally Posted by blueguy View Post
    Thanks for the reply and I was asking for the reason being I thought I may have a leak somewhere and after not finding one or anything wrong I wanted to be insured there were no issues and never thought about it like that
  9. #9 Re: Gtp lo boost
    Feb 2013
    37.295091, -121.930053
    i like you
    one of my step brother friends got a baby turbo car (dodge dart turbo) and was telling me that he wants to make 30 lbs of boost im like wtf no you don't want that you want to worry about the flow. better flow in and out makes more power. then he looked up what i was saying and then told me that i was right geee go figure creeping on this forum help out lol. i told him to get a tune on it and to run 91/93 in it. he was like well the owners manual says you can run 87 in it and i told him its needs the higher octane fuel. so now he run 91 in it and the engine is happy lol
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  10. #10 Re: Gtp lo boost
    Kemmerer, Wyoming
    i like you
    they set up those cars to be able to run on mid grade. I have a Cruze with the 1.4 turbo engine, and the book says you can put mid grade in. I put premium in because it makes more power and seems to get better gas mileage.
  11. #11 Re: Gtp lo boost
    Kemmerer, Wyoming
    here is an example of too much boost:
    http://www.powerblocktv.com/post/gt-...re-blowing-up/
  12. #12 Re: Gtp lo boost
    Mar 2015
    kankakee
    i like you
    Hahaha and thanks for not being all rude about it and just stating that so now I know
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  3. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
