Thread: P0449 error code - Check Engine light
Results 1 to 3 of 3
  1. #1 P0449 error code - Check Engine light
    Jul 2012
    Bloomington, IL
    2005 GTP
    My son just recently went on spring break to Gatlinburg,TN and took my 2005 GTP. During the trip through the mountains, the check engine light came on. He took it to Autozone, and it's throwing the P0449 error code. When I google it, it says:
    Evaporative Emission Vent Solenoid Control Circuit
    Any ideas what this means, and how to clear it?
    TIA,
    Jeff
  2. #2 Re: P0449 error code - Check Engine light
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Dont know what means some them will hand you the tool clear it yourself others flat refuse technically there not aloud clear codes any more can disconnect battery for like ten min reset everything
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  3. #3 Re: P0449 error code - Check Engine light
    Mar 2014
    Tucson
    Had the same thing happen when we took our minivan through the Appalachian mountain range on the way to Roanoke. Reset the code and it never came back.
    Best guess is, it had to do with the rapid change in air pressure from the difference in elevation. Reset and forget. I'd be willing to bet it won't come back.
  1. Check Engine Light: P0128 Code
    By mecsimm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-28-2013, 10:19 PM
  2. Check Engine Light w/code p0327.
    By bhawk in forum General Tech Discussion
    Last Post: 07-19-2011, 05:36 PM
  3. Check engine light/code
    By biggt in forum General Tech Discussion
    Last Post: 07-12-2011, 12:09 AM
  4. Check engine light on. Code: P0481
    By glomgold in forum General Tech Discussion
    Last Post: 03-22-2009, 04:10 PM
  5. *ERROR CODE INSIDE* Installed new PCM - Service engine light is on
    By Freebeer187 in forum General Tech Discussion
    Last Post: 11-23-2008, 07:05 PM
