Thread: P0335
Results 1 to 3 of 3
  1. #1 P0335
    Mar 2016
    Grand Rapids mi
    I have a 2008 Grand prix with the n/a 3800, I keep getting a code for p0335. It mostly happens when warm, first start of the day car runs good no codes but if I shut it off when it is warm and try to start it, it starts hard usually 3-4 tries. I have put a crank position sensor and checked the wiring for continuity and damage, everything looks good. Pulled the igtion module off and made sure everything was clean. I am looking at replacing the module but hate to spend the money if it is not the problem
  2. #2 Re: P0335
    Kemmerer, Wyoming
    did you do the case relearn after the replacement?
  3. #3 Re: P0335
    did you tq the bolts on the crank sensor, iirc its 13 or 14 fp.
  1. Replies: 3
    Last Post: 06-12-2014, 07:45 AM
