Thread: Swaping engine and trans from top ( first timer)
Page 32 of 33 FirstFirst ... 2230313233 LastLast
Results 621 to 640 of 645
  1. #621 Re: Swaping engine and trans from top ( first timer)
    Donating Users moddman's Avatar
    Midwest
    tune the rev limiter higher with dhp
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  2. #622 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Quote Originally Posted by moddman View Post
    whats dhv? could this also make the car stall?
  3. #623 Re: Swaping engine and trans from top ( first timer)
    its a 06 and thats not his issue clearly, but thanks for stopping by.
  4. #624 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Well, i guess its going off to the mechanic tmrw. you guys have done so much i really appreciate it all, Ill report back when he gives me any info.
  5. #625 Re: Swaping engine and trans from top ( first timer)
    GTP Level Member
    Oct 2014
    Good luck. Very curious.
  6. #626 Re: Swaping engine and trans from top ( first timer)
    pretty sure its something kinda simple. wish i could be with the car, cant really tell for sure over the web.
  7. #627 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I think so too Scotty, but worst case scenario, what's the worst possible vac leak there is and are they all fixable? Assuming it's not a lose hose etc
  8. #628 Re: Swaping engine and trans from top ( first timer)
    cant even say whats the worst, you dont want any leaks, and you got one. the shop will call you with what they find.
  9. #629 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I was hoping I wouldn't have to leave my car there. I don't know anything about these leaks but I can't imagine its so huge if the car can run for so long regularly before it stalls
  10. #630 Re: Swaping engine and trans from top ( first timer)
    its called un metered air getting into the engine, it fights to run. runs, then stalls out when the pcm freaks out. remember a computer runs the engine these days.
  11. #631 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    This was a head scratcher for them too, hopefully by tomorrow Ill have an answer, nothing obvious popped up on the fancy snap on machine.
  12. #632 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    OK, so its been fixed for the better part of the day. The mechanic said somethings were loose like sensors near the ac and he also mentioned the wires on the starter bolt not making enough contact(I tightened the sh*t out of them?) It did take him a long time to figure out what the problem was, he called me few times to verify I had done things like tc bolts etc. Anyway it was not a vac leak or anything major just something petty and small I hope, Im not fully convinced by his reason but i dont care at this point as long as it stays working. That cost me 100 alone. I was glad to pay that at this point.
    Here's a price break down if anyone cares or is wondering what this might cost. Extra parts not related to engine/trans swap can be deduced from total.
    615 Engine(1k miles)
    620 Trans(55k miles)
    326 radiator hoses wires oil filters fluids coolant plugs carb cleaner etc
    140 2 ton hf engine crane
    68 tools
    40 lower control arm(busted ball joint while separating knuckle to remove axle)
    15 crossover pipe (busted it by lifting engine from here by accident)
    43 code reader machine
    15 3 separate admissions to pick your part
    100 mechanic (after i couldn't figure out why car stalled after starting)
    1982$
    Now if if yore just doing engine/trans only with fluids,plugs wire etc it wouldve only ran me about 1500, I decided to put a new rad and broke some parts as well. I still saved a good amount on whatever i would have paid someone else for labor(lowest quote i got was 1000), some money couldve been saved had i borrowed or rented a hoist or tools but i decided to buy instead, also being careful when removing things could've saved me about 50 bucks as well. Overall it was a great experience I want to try to this in another car. But for now I will be looking into rebuilding the engine i have here, something tells me theres nothing wrong with it. Thanks once again to all he people who spent a lot of their time answering my noob questions having patience and posting pics etc.
  13. #633 Re: Swaping engine and trans from top ( first timer)
    what ever he did 100 bucks is a good deal really to hunt and find things and then get it to run again.
    make sure you get an alignments now, with all the front end parts being changed, struts taken off the knuckle and all you need one im sure.
    rebuilding these engine is not cost effective at all, will run you around 2 grand easy. why used engines are king.
    good luck, hope it goes well down the road.
  14. #634 Re: Swaping engine and trans from top ( first timer)
    Buffalo
    Would love to know what he did though ...
  15. #635 Re: Swaping engine and trans from top ( first timer)
    Jul 2010
    Coquitlam,BC,Canada
    And a back-yard mechanic is born.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  16. #636 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Quote Originally Posted by Bronco Boy View Post
    Thanks, that gave me a good chuckle. I was actually not doing any actual work of my own just relaying everything you guys told me to do plus bills tutorial=a newish gp
  17. #637 Re: Swaping engine and trans from top ( first timer)
    Aug 2016
    ontario
    Quote Originally Posted by brettstoner View Post
    any of you guys know the thread size and pitch of the trans to engine bolts? I am going to pull my motor next month and want to throw it on the stand while i top swap and cam it.
    Thanks.
    m12x1.75
  18. #638 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Its been about a year since the swap and I wanted to update the thread a bit along with some questions. Ive been very happy with the swap, it's been reliable after almost 20k. The engine has been great the transmission not so much. Ive been getting the 742 stuck off code and I get a stall and jerk during take off sometimes like hiccup. I also hear the sound of a disk making contact with something when I turn the car off, kinda like a bad rotor but coming from the trans area while stationary. Talked to a car guy and he mentioned I might need to get inside the trans to fix?
    2nd problem- I replaced the down pipe to pass smog (was getting 420 code)now there's an exhaust sound, imagine the sound of those great little 80's toyota pickups taking off, that little rattle they ALL make like a few bbs are flying around in there. The sound gets louder as I accelerate, it's like a fast ticking sound. I first assumed it had a bad catalytic so I put the other one I originally had on and sure enough the ticking persisted. Could it be a faulty flange? The sound is embarrassing, made the car sound old and haggard, specially when going 2500 rpm+. The replacement DP didnt throw the code after a couple days and it looks in great shape(used),I hope that's not it. what do you guys think?
  19. #639 Re: Swaping engine and trans from top ( first timer)
    gonna need a vid of these sounds.
    tranny sounds like its toast.
  20. #640 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    It's hard to get it recorded with the wind at those speeds but its a typical clicking tick that correlates with the acceleration. No more clean sounding purr more like a clanky old truck.
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
