Thread: Swaping engine and trans from top ( first timer)
Page 25 of 33 FirstFirst ... 152324252627 ... LastLast
Results 481 to 500 of 645
  1. #481 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    The spark plug is not suppose to have fuel on it is what he is saying.
    How could spark plug get fuel on it? do you mean fuel injector plug?
  2. #482 Re: Swaping engine and trans from top ( first timer)
    exactly, if the spark plug is wet the injector works and the plugs not lighting up and causing the misfire.
  3. #483 Re: Swaping engine and trans from top ( first timer)
    Quote Originally Posted by steelholder View Post
    you do understand how a engine runs right? the injector sprays gas in the cylinder, the spark plug sparks and it blows up inside the cylinder, no spark = wet plug. if its not soaking wet, it will stink of raw gas.
    best to run it for a minute, then pull that plug out.
  4. #484 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    i had a lower than average iq moment and completely forgot about the other end that screws onto the engine. I kept thinking"how could the ceramic part of the spark plug get gas on it"..ive been having these moments too frequently this last week. ill be checking that and swapping the coils.
  5. #485 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Ok guys swapped coils after smelling gas on plug, everything feels perfect no more shaking and codes gone only one left is p0418 gna go test drive it.
  6. #486 Re: Swaping engine and trans from top ( first timer)
    check around the air pump for a plug you may have left off.
    all in all good job. happy test driving.
  7. #487 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    yes i never found the other plug that mated to that little blue one near the air box i looked all over the axle. I did notice that the gp at the yard also had it unplugged when all the ones around it were still plug in, couldve been a coincidence.
    The car drives so nice, i drove it about 4 miles around my house, this hasnt settled in yet. I cant thank you guys enough.
  8. #488 Re: Swaping engine and trans from top ( first timer)
    no problem. this site is always good for a helping hand.
    we all have stray plugs in the bay that go to nothing. so that maybe the case.
    glad to hear shes up and running. well worth saving that grand on labor, i bet your only 300 deep out of pocket at this point due to ripping your axles apart and junk yard runs for little parts. minus the cost of the new engine and tranny of course.
  9. #489 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I have a list with all costs associated with this project, ill be posting the numbers in a bit, but without a doubt i saved a lot and learned a sh*t load of new stuff, by force lol.
  10. #490 Re: Swaping engine and trans from top ( first timer)
    the thought of not paying a shop is always on my mind, i hate handing over cash for stuff i can do myself. at this point my only shop time is alignments. cause i just cant do one at home lol been that way since the 80's. unless the car had a warranty still, then i let the dealer deal with it for free. cause its free. i dont like them monkeys touching my stuff really, but its free.
  11. #491 Re: Swaping engine and trans from top ( first timer)
    GTP Level Member
    Oct 2014
    Thanks for tackling this steelholder and scottydoggs for being there for troubleshooting. Followed from the beginning. I have never pulled an engine or tranny but with the help here I feel it's very do-able. I do all my fixing and maintaining on cars and like Scotty hate paying others to do stuff. Luckily never had to go that deep. I probably should have played with my old 2000 GP with 330K on it when it froze up, my guess now is it hydro locked but everything was used up on that, body, original struts and interior only an SE also. I have 2 daughters driving GP's now that are both supercharged an 07 and an 03 with 168k and 200 k respectively. Kind of jealous I don't get to drive them more. The are a blast to drive.
    Thanks again for the education.
    Sent from my iPad using Tapatalk
  12. #492 Re: Swaping engine and trans from top ( first timer)
    Jul 2010
    Coquitlam,BC,Canada
    The car drives so nice, i drove it about 4 miles around my house.....
    Good news.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #493 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Ok guys everything was great for the first ten miles. When I was pulling ouy after turning car off the car turned off like it had no gas now i can't keep it on turns off after a few seconds.
  14. #494 Re: Swaping engine and trans from top ( first timer)
    So you mean it starts, run for 2-3 seconds and shuts off??
  15. #495 Re: Swaping engine and trans from top ( first timer)
    make sure theres pressure in the fuel rail. turn the key to run, then push the pin in. its under the black cap.
  16. #496 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Starts to sputter as soon as it turns on stays on if given gas but sputtering
  17. #497 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Gas sprayed out when I pushed the pin
  18. #498 Re: Swaping engine and trans from top ( first timer)
    Something sensor related, seems like fuel pressure is fine.
  19. #499 Re: Swaping engine and trans from top ( first timer)
    re scan it, you may have a pending code for that tps again.
  20. #500 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I did I'm only getting p0418 and p0420 came back too
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
