Thread: Swaping engine and trans from top ( first timer)
Page 22 of 33 FirstFirst ... 12202122232432 ... LastLast
Results 421 to 440 of 645
  1. #421 Re: Swaping engine and trans from top ( first timer)
    Buffalo
    I understand the motorcycle reference now
  2. #422 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Any ideas on why there's no gas pedal response?
  3. #423 Re: Swaping engine and trans from top ( first timer)
    take the tb from your engine, and use that one. the jy engine tb may not be the same part # for the tps = throttle position sensor.
    clean the piss out of the old one.
  4. #424 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I'll compare part numbers them when I get back the jy line was insane
  5. #425 Re: Swaping engine and trans from top ( first timer)
    id just swap the whole tb over, you know that one worked on your car.
  6. #426 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    yep you were right there was a set of different series of numbers that didnt match up on either tb. gna clean it and throw it on with the other crossover pipe.
  7. #427 Re: Swaping engine and trans from top ( first timer)
    taking the tb off first then do the cross over adds some room.
    lets hope this makes it all right now.
  8. #428 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    yes this made all the difference no more horrible rumbling etc. also have the gas pedal reaction after replacing the tb. The car is still is shaking much more than it should(maybe i missed a bolt that secures it to the trans or bracket etc?) and smoke is really coming out of the exhaust manifold area i cant tell if its one or both but its coming out of both ends, smoke smells real burnt so i turned it off after a couple minutes. at least i can tell the engine runs nice and quiet though. should i post a new video?
  9. #429 Re: Swaping engine and trans from top ( first timer)
    Any check engine light codes??
    Maybe something isnt plugged in all the way or you have a vacuum leak somewhere. A unplugged injector or bad vacuum leak can cause the motor to shake.
    And it's possible that smoke is just oils that are burning off still.
  10. #430 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    the light does turn on but i dont have the reader atm. I thought it might be liquid burning off but it seems to start to flow out in a consistent manner from the the areas mentioned.
  11. #431 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Here's the updated vid smoke is coming out less but look at the rear manifold area. It also sounds less choppier than the audio on vid.
    https://youtu.be/v-0ZbEH4zqQ
  12. #432 Re: Swaping engine and trans from top ( first timer)
    Still just looks like a little bit of oil burning off, looks pretty faint and not just straight smoking up a storm.
    Once you figure out the check engine lights, then you can move on further. Hard to say what else needs to be done without knowing what the codes are.
  13. #433 Re: Swaping engine and trans from top ( first timer)
    does seem like a misfire. make sure all the plug wires are still good, you had them laying over the manifolds if they got a burn spot its now bad most of the time.
    double check all the injector plugs too. if you can get it scanned would be a huge help.
    the smoke looks like your greasy hand prints burning off the manifold.
  14. #434 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Hopefully i could get those posted up by the end of the day. I noticed there are two empty bolt holes on the front bottom right of my engine that look they should hold some bracket or something of that sort. I did a really good job of organizing everything i took off and i cant remember if anything goes there. Nothing that goes down there is left. Is there a diagram showing which areas of the engine/trans connect to frame? Thesse two holes are just to bottom right of the sensor on the pan.
  15. #435 Re: Swaping engine and trans from top ( first timer)
    theres a bracket between the tail of the tranny and the engine block near the oil filter, you should have had that bolted back in engine out still.
  16. #436 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I got that one covered,the two holes im referring to would be visible if youre standing in front of car near bumper its at the most bottom right corner of the engine, two sequential bolts or holes?
  17. #437 Re: Swaping engine and trans from top ( first timer)
    in the bell housing to engine? take a pic so we can be on the same page. worth a 1,000 words every time.
  18. #438 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I meant bottom left corner
  19. #439 Re: Swaping engine and trans from top ( first timer)
    once again, take a look at your old engine, see if those two threaded holes are there, this engine came out of a different car remember. theres bound to be a few small differences.
  20. #440 Re: Swaping engine and trans from top ( first timer)
    http://www.grandprixforums.net/threa...l-disappearing found this thread, pics tell me your ok as is, something ont he other car may have been bolted there, why it looks so clean.
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
