Scottydoggs
you know what, i bet you need your torque converter bolts, with the starter out, look in the hole, put a socket on the crank bolt in the balancer and turn the engine if you can still. as you turn it you'll see 3 bolts, remove them, you'll need them for the new engine.
if your engine is locked up, you'll need to buy new tc bolts.
