Thread: Swaping engine and trans from top ( first timer)
Results 1 to 20 of 645
  1. #1 Re: Swaping engine and trans from top ( first timer)
    leave the engine and tranny bolted together, lay it on the floor for scrapping the good parts off it.
    you will want to mate the new tranny and engine before installing it.
    you know what, i bet you need your torque converter bolts, with the starter out, look in the hole, put a socket on the crank bolt in the balancer and turn the engine if you can still. as you turn it you'll see 3 bolts, remove them, you'll need them for the new engine.
    if your engine is locked up, you'll need to buy new tc bolts.
  2. #2 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I just remembered this part, I didnt actually remove the starter i just disconnected the wire and put nuts/bolts back on. Is this something i can do when its pulled?
  3. #3 Re: Swaping engine and trans from top ( first timer)
    i dont know about cable. get a chain and bolt it to the sides of the heads diagonal across the engine.
    engine and tranny is like 500 lbs easy, its not light. full engine is just over 300, trannys got to be around 200
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
