Thread: Swaping engine and trans from top ( first timer)
Page 5 of 33 FirstFirst ... 3456715 ... LastLast
Results 81 to 100 of 645
  1. #81 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    engine hoist is cheaper lol you can rent them too.
    even if you take 3 days getting it done, your ahead of the game on the cost. and then got the satisfaction of saying, look what i did...
    being your doing both engine and tranny, you can ull both from the top together, or un hook it all take the sub frame bolts out, then you lift the front of the car up with the hoist and theres your engine and tranny on the sub frame still.
    how to for both out the top as one. http://www.grandprixforums.net/threa...highlight=easy
    cant seem to find a how to for out the botom, but found some pics. you need to un hook the same things engine wise, aka wires, then un bolt and free the rack from he frame, un bolt the struts from the top clear all the wiring p/s lines and stuff, then lift the car up and you can drag the frame with engine and tranny out from under the car, then do all the swap work in the clear.
  2. #82 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    Thats a wickedly small thread but it seems to break evrything down well. I cant beleive im considering doing this now, like you said it would be extemly satsfying knowing i did it. Worst case scenario is i screw up and just pay someone anyway.
  3. #83 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    i just kept the nuts and bolts with what ever parts came off, put the bolts in the holes to keep em safe and in place for your memory.
    loose bolts got grouped together on the windshield cowl, what GM made that shelf for. wire plugs only go one place, when you lay the harness back over the engine the plugs tend to lay right where they came from, i even had a injector plug land dead on the injector, all i had to do was push it on. aka putting all the plugs back on is mindless really.
  4. #84 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    Gna do some hw today, luckily i have the time to cruise around the web and this forum specifically that was a great thread i hope to find more like it. Ill start grouping some tools up i think i have most of what was on the list
  5. #85 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    in LA iirc there are shops you can rent a bay from, all tools and a lift by the day. iirc it was like 125 a day? you may want to look that up. could make life much easier in the end.
    they are diy shops, all they do is rent space with tools and lifts.
  6. #86 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    There are, but i prefer just having everything here and doing it in my garage. For the cost of one day i could buy a cherry picker for 100 locally itll also take much more than one day im sure, as i work and will only have time after or on the weekend. I wonder which is easier pulling from top or dropping from bottom
  7. #87 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    as for working in your garage, if you back in and work near the door, take note how high the garage door is, my friends garage where i did my swap has a high door, like 8 foot high. most standard doors the hoist will hit the door.
    top of the pic you can see the door track and door.
  8. #88 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    Ill probably be doing it in the front driveway of my garage i have empty space there. once i buy the hoist theres no turning back
  9. #89 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    If anyone can think off the top of their heads of a good link for 07 or same engine trans removal please post here
  10. #90 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    the one listed will cover you fine. very few things are changed. like the tb has no cables, and theres only one fuel line to the rail. likely about it
  11. #91 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    So i got started i want to start a new thread though, or should i keep this one going? Should it go under tech or discussion?
  12. #92 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    keep it rolling, change the title if you like.
  13. #93 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    This is what i removed today, not pictured air box, alternator and icm
  14. #94 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    Heres the right side wth tb removed a
  15. #95 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    Left side without alternator and icm
  16. #96 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    You are pulling each piece seperately, which isn't outlined in the thread. follow the thread to nearly a T and you can have a motor swap done in say 6-8 hours first time out.
    I've bought so many JY motors it's silly. Out of probably 50+ I had one bad one, and they treated me right on that one when I called and nicely mentioned it.
    holler if something comes up.
  17. #97 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    The thread won't mention your secondary air injection. Pop one of the plastic clamps and the rubber hose. That will be plenty to get it out. Just ensure you move over that rear manifold and it's associated crap if the new one doesn't have it.
  18. #98 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    Filthy black tb look at the inside of that hole dam. What a difference!
    i think i completed everything or most up through step 7 in thread above. Im ashamed to say i didnt know what some of those abb stood for so i just disconnected anything i saw and kept in grouped in boxes.
  19. #99 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Sorry..probably should have gone back and changed those to the full words. You know though...when you've done it too many times...it can sometimes feel too second nature to use the abb's
    Based on your picture.. I'd push her outside and flush the heck out of the heater core and radiator. Those coolant ports are disgusting.
  20. #100 Re: Anyone ever bought an engine from a salvage/wrecking yard?
    Apr 2011
    North Los Angeles
    No worries i just noticed your the guy who created that thread THANK YOU. And i wont be straying from the steps anymore i just knew id be replacing the tb and alternator and air box anyway.
    what and where is this secondary injection not mentioned?
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
