Thread: Swaping engine and trans from top ( first timer)
Page 18 of 33 FirstFirst ... 8161718192028 ... LastLast
Results 341 to 360 of 645
  1. #341 Re: Swaping engine and trans from top ( first timer)
    i dont know whats going on then dead wires dont spark or make it crank over. only way is if you had power to the cable still, going on or off it will spark and if you tag the little stud it will crank.
  2. #342 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    It's plugged in now it wasnt earlier when intalled it it. Im gna take a pic of this dam thing
  3. #343 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Is this what you meant by smaller stud making contact with the positive wires?
  4. #344 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I noticed that black wires metal resting right on that baby bolt to the side
  5. #345 Re: Swaping engine and trans from top ( first timer)
    the black cable is th emain ground off the battery, your gonna melt the car down, take the black one off put it on the tranny bolt.
    your missing the large eyelet thin wire to the large stud too.
  6. #346 Re: Swaping engine and trans from top ( first timer)
    see large eyelet with two wires, behind it its the red cable.
  7. #347 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Here's my ground to the trans right behind the air pump
  8. #348 Re: Swaping engine and trans from top ( first timer)
    Antioch, IL
    put the black wire from the starter on it
    2009 Challenger SRT8
    Expert at being gay.
  9. #349 Re: Swaping engine and trans from top ( first timer)
    im telling you that black cable is the neg cable take it off the starter and put it on the tranny already.
    see pic i posted, it shows the colors of the other wire that goes on the stud, all black wires are grounds, end of story there, you on board?
  10. #350 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    The black cable on the starter is about six inches long it would be impossible for it to reach the trans the cable for the little stud stems from the same place
  11. #351 Re: Swaping engine and trans from top ( first timer)
    it dont belong there, im telling you. trace it back, its going to the battery. go back and look at the diagram and other pics posted, you dont see a black cable on the starter ever. just red and orange grey and the little purple one.
    and the ground is only 6 inches from the starter stud.
  12. #352 Re: Swaping engine and trans from top ( first timer)
    Antioch, IL
    Factory harness battery to starter, postitive on battery goes to positive on starter, goes no where else
    Neg from battery goes to transmission bolt, NO WHERE ELSE.
    Untitled by Corey S, on Flickr
  13. #353 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Vc
  14. #354 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Ok thanks guts ill switch it again this has got to be the fifth time today
  15. #355 Re: Swaping engine and trans from top ( first timer)
    Antioch, IL
    the black wire goes to the transmission bolt for a ground
  16. #356 Re: Swaping engine and trans from top ( first timer)
    this is how i kinda feel right now lol
  17. #357 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    There are two bolts attached to trans with black cables. One holds the starter from behind and the other bolt is directly behind air pump. Do I put this one behind the pump or on the bolt connecting starter to trans behind starter?
  18. #358 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    ,lol beleive me i feel pretty dumb about it good laugh
  19. #359 Re: Swaping engine and trans from top ( first timer)
    pics of it all, your done went and f ed up big time now. this aint rocket science
    and theres two bolts that hold the starter on, thats it, no bolts behind it.
    all black loose wires go on the tranny stud on that one bolt.
  20. #360 Re: Swaping engine and trans from top ( first timer)
    Jan 2014
    AR
    LMAO
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
