Thread: Brake fluid leak
Results 1 to 9 of 9
  1. #1 Brake fluid leak
    Mar 2014
    canada
    Hi there.
    A 2000 Pontiac GrandPrix SE
    My brothers car has been topping up the brake fluid,and other fluids,like coolant for several weeks,then he starts the car,and it drives,and brakes just fine.This is on advice from his mechanic.
    My brother says the brakes work just fine.
    I,m wondering if there will be a gradual decline in the brakes performance,or would it be a sudden one,as in the brakes stop working just like that?
    He will be taking it back to the same mechanic on Friday,and asking the same question.
    Thanks
  2. #2 Re: Brake fluid leak
    a brake leak should be fixed asap, it can completely blow out and leave you with no brakes at all. and then crashed of course.
    if a mechanic told you to just keep topping it off, never go back to him. hes a asshole.
    sit in the car pump the brakes a whole lot, then get under it and look for the leak. then fix said leak.
  3. #3 Re: Brake fluid leak
    Feb 2013
    37.295091, -121.930053
    quick story had a van one time with a small oil leak then one day when it was raining the van spunk around due to the breaking getting covered in oil. if you dont have breaks you cant stop soooo yeah
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: Brake fluid leak
    St. Louis
    Fix brake leak, then do the LIM gaskets before the motor spins a bearing due to eating coolant if that's where it's going. I wouldn't drive it until the brake leak is found and fixed. I had brakes go out completely on me once in my 84 CV and I thought I was going to kill the cars in front of me. Luck and quick thinking was all that saved me that time. Never ignore a brake issue.
  5. #5 Re: Brake fluid leak
    Jan 2014
    AR
    Could be the reservoir leaking. Dude might have topped it off because his brake pads are going away and calipers are extending farther, resulting in low-ish level in the MC res.
  6. #6 Re: Brake fluid leak
    Mar 2014
    canada
    Quote Originally Posted by idrivejunk View Post
    Wish i was living in the U.S.
    My brother just confirmed that it is not a Grand Prix,but it is a 2000 Grand am.
    All along its been assumed by me that it was a GP,as thats what we both thought at first,so he never mentioned it until this issue surfaced.
    I,m guessing it doesn,t matter on the type of car whether its a GP,or GA.
    Either way it will be looked at tomorrow.
    Thanks for the replies,and any more that come.
  7. #7 Re: Brake fluid leak
    Mar 2014
    canada
    Updates in realtime:
    Sounds like it could also be the reservoir leaking,and thats why it needs topping up on daily basis,after driving it on those crappy roads we all have in our cities.The brake line may also be rusty.
    How big of a concern is that ?
    My brother says the mechanic hasn,t seen the car in a little while,that it has been mostly phone calls,with updates,and feedback from the mechanic on what to do.The car is not driven very far ,mostly
    for errands around the neighborhood.
    Apologies for any miscommunication/misunderstanding on my part.
  8. #8 Re: Brake fluid leak
    what does stop driving it and fix it mean?????
    if he cant figure it out, drop it off to be fixed before his dumb ass kills someone.
  9. #9 Re: Brake fluid leak
    Mar 2014
    canada
    The Mechanic was mistaken.
    It turns out it is the engine that is leaking oil.
    I,ve been trying to get to the bottom of this whole thing for days,being under the wrong impression also.
    The Mechanic does not speak english very well,but having the car on the hoist all day today was what cleared things up finally.
    I,m just a messenger,not my car.
    Thanks for all your concerns though
  1. Brake fluid leak
    By shawngerkin in forum Introductions/Noob Questions
    Last Post: 11-07-2013, 01:00 PM
  2. pinkish fluid leak?!
    By blkgtp2000 in forum General Tech Discussion
    Last Post: 05-24-2013, 03:09 PM
  3. Transmission fluid leak
    By LowRidinCrew in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-04-2012, 04:06 PM
  4. Fluid leak
    By boarder003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2012, 08:05 PM
  5. Brake Fluid Leak
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2011, 10:47 AM
