Thread: Fuel Pump? Studdering Under Acceleration
Results 1 to 6 of 6
  1. #1 Fuel Pump? Studdering Under Acceleration
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, I was all excited after I got my O2 sensor in and took it for a test drive today and under ANY acceleration, and occasionally when not accelerating the RPMs jump around hundreds like crazy. And sputters and doesn't really want to accelerate very fast or much. And, I could swear I hear a ticking/clicking noise from my engine that's more pronounced than when I listened to my parents' '07 GT (or maybe I'm hearing things)... Also, when I last started it in the shop now it seems to idle a bit loopy like it does on the road under acceleration.
    I've replaced the MAF, tested MAF wires and ran new MAF to PCM wire, and replaced O2 sensor and wires.
    Additionally, the old P0102 code came back again that I keep having. Fuse #21 no longer blows.
    https://youtu.be/rOyTWpcqHFk Sorry for the orientation, didn't realize I had it that way...
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: Fuel Pump? Studdering Under Acceleration
    hangover park IL
    if the oxygen sensor you bought is a Bosch take it out throw it in the garbage and get a Delco or Delphi or Denso oxygen sensor. I've had more problems with Bosch oxygen sensors than almost any other replacement part
    ~James~ Psychotic Gearhead
  3. #3 Re: Fuel Pump? Studdering Under Acceleration
    SWPA
    I'm assuming you replaced the upstream o2? If the sensor itself isn't the issue you might want to make sure you didn't damage the #6 plug or wire.
  4. #4 Re: Fuel Pump? Studdering Under Acceleration
    Jun 2015
    I was warned against Bosch O2 sensors, it's a Denso.
    Yeah, upstream O2. I unplugged it and ran a new wires from the O2 plug along the firewall and up by the coolant tank and over on top, like what Scotty did, wasn't anywhere near #6 plug.
  5. #5 Re: Fuel Pump? Studdering Under Acceleration
    Donating Users timboku's Avatar
    Montgomery, IL
    Was it doing this before you replaced 02 sensor l..sounds kinda like a failing icm
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  6. #6 Re: Fuel Pump? Studdering Under Acceleration
    Jun 2015
    Yup, was doing it before I replaced the O2.
    Is this possibly the fuel pump? If it's not too hard I could swap it with my part's car one and see if it changes anything...
    EDIT:
    Thanks to Scotty's suggestion I swapped the MAF from my extra TB and low and behold she runs like a top, no engine codes, no studder, all fixed!
  1. 04/05 fuel pump install- Fuel pump access in trunk
    By chrsmi1 in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2015, 09:26 PM
  2. Replies: 7
    Last Post: 11-05-2014, 10:09 AM
  3. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  4. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  5. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
