Thread: No Air Coming Out of Vents
Results 1 to 4 of 4
  1. #1 No Air Coming Out of Vents
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    I tried Googleing around, but couldn't find any situations like this.
    2007 GP GT s/c
    Any fan setting you can hear the fan, but it won't blow hardly anything out of the vents. You can hear it chug away like its blowing (increased blowing noises as you turn the fan setting higher), but hardly anything comes out. The little bit of heat that comes out is warm, so there doesn't seem to be an issue there. It was just random, one day the heat wouldn't blow out of any of the vents on any setting, fiddled with passenger/driver dual climate, head/feet vents, ect. nothing. Defrost vent on the dash works.
    Any ideas what the issue might be?
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: No Air Coming Out of Vents
    could be a busted vac line off the top of the sc, it goes to the firewall then down the pass side fender then under the fuse box. battery change can break the line.
    if the line looks ok, it could be the box behind the dash that vac line leads to, or the climate control went bad.
  3. #3 Re: No Air Coming Out of Vents
    Middle line on the supercharger vacuum tree on 2004+ cars is capped from the factory, so it's not that.
  4. #4 Re: No Air Coming Out of Vents
    do the vents not work off vacuum power still on the 04 up cars?
  1. Heat doesn't work '07 GT
    By TJNAPPY in forum General Grand Prix Discussion
    Last Post: 09-22-2015, 07:19 AM
  2. No heat from vents
    By wideout22 in forum General Tech Discussion
    Last Post: 09-15-2014, 09:44 AM
  3. A/C & Heat Vents Issue? 99 GT
    By corxbeans in forum General Grand Prix Discussion
    Last Post: 06-17-2013, 10:45 PM
  4. Doesn't heat
    By crimson red in forum General Tech Discussion
    Last Post: 11-01-2011, 11:19 PM
  5. No heat from driver side vents!!!!!!
    By Blown38 in forum General Tech Discussion
    Last Post: 01-31-2010, 05:09 PM
