Thread: Heat doesn't work '07 GT
Results 1 to 6 of 6
  1. #1 Heat doesn't work '07 GT
    SE Level Member TJNAPPY's Avatar
    Apr 2015
    Rockland County, NY
    So, everything else on the Climate Control panel works, except the Heat. I set it to 90, normal car air blows out and I tried all the setting combinations. Air Conditioner still works excellent.
    Any advice on what's wrong? Thanks
    2007 Grand Prix GT (S/C), Jewel Red Tint-Coat, 5% Tint, Cross-Drilled Rotors.
    1995 Grand Prix SE, stock.
    2008 Corvette, Velocity Yellow, Z06 Intake, Flowmasters, LS3 Predator Tuned.
    R.I.P Pontiac's 6000LE, SSEI, SSE, Sunbird, Formula and WS6
  2. #2 Re: Heat doesn't work '07 GT
    flush the heater core. its air bound likely.
  3. #3 Re: Heat doesn't work '07 GT
    I'm totally with BillBoost, because, he's always right
  4. #4 Re: Heat doesn't work '07 GT
    Always.
  5. #5 Re: Heat doesn't work '07 GT
    Aug 2015
    Reno, Nevada
    Had a problem like this on a 98 gtp. But it would blow cold air only on the passenger when set to heat on dual climate control. Turns out it was a faulty blend door actuator, the plastic gears inside were binding. If only one side is blowing cold it's the actuator. If both sides are cold it's probably a clogged heater core like Scotty said I mean Bill
    99 GP GT Coupe
    279,942 Miles
    K&N and de-badged
  6. #6 Re: Heat doesn't work '07 GT
    Apr 2015
    Rockland County, NY
    Ok, thanks. I'm taking it in to the mechanic Saturday and will let you know what was wrong. Thanks.
  1. My DIC doesn't work
    By bonerjamz03 in forum General Grand Prix Discussion
    Last Post: 09-26-2015, 03:19 PM
  2. a/c doesn't work
    By tyler95 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-13-2014, 06:29 AM
  3. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  4. Doesn't heat
    By crimson red in forum General Tech Discussion
    Last Post: 11-01-2011, 11:19 PM
  5. DIC doesn't work at all.
    By hubert hefner in forum General Tech Discussion
    Last Post: 05-29-2010, 10:32 PM
