Thread: Need advice trouble shooting this
Results 1 to 18 of 18
  1. #1 Need advice trouble shooting this
    SE Level Member brokeazfunk's Avatar
    Aug 2013
    Phoenix Az
    Need help trouble shooting my performance shift button and wanted to know if anyone has a link or diagram that would help. I have tried searching here and google and no luck. I found a ton of related issues but they all ended up being something simple.
    I know most of you guys think the perf shift is useless but my pcm was set up to only activate the performance tune settings when its in perf mode. Without it working i have a stock car as far as the pcm is concerned.
    I know yall have heard this a hundred times lol. If I push the button I hear a very light click and the word performance flashes on the dash display but does not stay lit. I pulled the center console apart and the button wires look good and are connected.
    I fully expect to be given crap for this but any help would be appreciated. Im just hoping someone has already been there, done that and knows what I should try.
  2. #2 Re: Need advice trouble shooting this
    the button maybe bad. can you see if it stays in or not? i know mine does, but it stays in just a little bit.
    i also have the perf shift part of the tune set up with the 6000 rpm shift points, shifts stock with it off.
  3. #3 Re: Need advice trouble shooting this
    Mar 2014
    Tucson
    The wires may look good, but the only way to be certain the switch is working properly it to check it with a multi meter.
  4. #4 Re: Need advice trouble shooting this
    Aug 2013
    Phoenix Az
    Ok. I just assumed when it clicks that it's working lol. I'll check the button when I get home. I do have a good multi meter so I'll just check through the button with the car off to see if it makes and breaks like it should.
  5. #5 Re: Need advice trouble shooting this
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Wait, where is this performance shift button? Do all GTPs have it?
  6. #6 Re: Need advice trouble shooting this
    its on the shiftier. it ended in 02 i think.
    the pcm will put its self in perf shift mode when floored tho.
  7. #7 Re: Need advice trouble shooting this
    Dec 2008
    ****'s Creek
    Woo hoo i have an 02, gonna go look right now!
    Sent from my SPH-L720 using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  8. #8 Re: Need advice trouble shooting this
    if you dont have it you can add it. you need it turned on in your tune, then a new pinned wire installed in the the pcm to a switch.
  9. #9 Re: Need advice trouble shooting this
    Dec 2008
    ****'s Creek
    No good can't find a switch. Was it an option?
  10. #10 Re: Need advice trouble shooting this
    it was standard on sc cars with the hd tranny only. then it went away.
  11. #11 Re: Need advice trouble shooting this
    Dec 2008
    ****'s Creek
    Have the SC car and HD trans, maybe it stopped in '01?
  12. #12 Re: Need advice trouble shooting this
    Aug 2013
    Phoenix Az
    Sorry guys. Ive had a bad few weeks and have been crazy busy, and broke a damn tooth in half! anyways, it turns out that the button is bad. It wont stay engaged when I push it in. With the car off, I push the button and can hear a click and then when I let go, a slight crunchy click happens.
    I assume that it is just a spring loaded make and brake switch. So I could just cut the wires and run them to a basic flip on/off switch anywhere right?
  13. #13 Re: Need advice trouble shooting this
    or get another shiftier knob. where my button is in a regal, not so sure bout you gp people. if its on the dash a toggle switch should work fine, but a factory button will look way better i think.
    parts stores have all sorts of on/off buttons too. id hit a junk yard first tho.
  14. #14 Re: Need advice trouble shooting this
    Aug 2013
    Phoenix Az
    Mine is also a thumb push on the shifter. That would look better but it seems like a pain in the ass to change lol.
  15. #15 Re: Need advice trouble shooting this
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    you can go to the junkyard and pull an entire shifter assembly its not that hard to remove the console
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  16. #16 Re: Need advice trouble shooting this
    just the knob and button will come off the stick. no need to do a whole swap.
    ive seen em for sale in some older threads.
    and theres a thread or two with a shortened shift stick, shows how the knob comes off.
  17. #17 Re: Need advice trouble shooting this
    Aug 2013
    Phoenix Az
    Quote Originally Posted by ScottyDoggs View Post
    if I can find that "how to" then I may try this. Thanks guys.
  18. #18 Re: Need advice trouble shooting this
    Jul 2010
    Coquitlam,BC,Canada
    Shift knob upgrade..... http://chrisb.users.superford.org/Gr...hift_Knob.html
    I don't have it hooked up, but it gets "clicked" a lot when I am waiting at stop lights. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. MIL Control Circuit trouble shooting
    By JimSWylie in forum General Grand Prix Discussion
    Last Post: 05-04-2014, 07:57 PM
  2. Where the radiator fan switch? (need trouble shooting help)
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 05-01-2014, 06:07 PM
  3. P0411 - secondary air flow - Trouble Shooting Help - 06 GP
    By penright in forum General Tech Discussion
    Last Post: 03-20-2014, 03:15 PM
  4. Trouble shooting ???
    By my98gtp in forum General Tech Discussion
    Last Post: 02-23-2011, 12:38 AM
  5. trouble shooting
    By 403mike0585 in forum General Tech Discussion
    Last Post: 01-13-2011, 05:53 AM
