Thread: What's the deal with our gas tanks?
Results 1 to 14 of 14
  1. #1 What's the deal with our gas tanks?
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Every time I get gas I have to move the pump around probably 10x before it finally finds a spot it likes. Is the tube bent funny where the pressure backs up or something? Sometimes it gets crazy aggravating and I'm ready to hose the car and set it a blaze rather than deal with it again.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: What's the deal with our gas tanks?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    My dads mustang is the same way. I think the bend is too restrictive which splashes gas back on the nozzle tricking it into thinking its full.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  3. #3 Re: What's the deal with our gas tanks?
    Antioch, IL
    Its the EVAP doing that
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: What's the deal with our gas tanks?
    Jan 2014
    AR
    I've found that if I allow a few moments after removing the cap for fumes to escape, I don't have this problem. Solved it by simply opening the cap first then paying or using card. Usually takes fuel in like normal once the tank pressure equalizes with the atmosphere.
  5. #5 Re: What's the deal with our gas tanks?
    I only stick the nozzle in 1/4th to half way, works fine like 9/10 times.
  6. #6 Re: What's the deal with our gas tanks?
    Buffalo, NY
    idrivejunk, I'll give that a try next time.
    I've found that this works but sometimes the gas bubbles up and out before it clicks off. It stays in the nozzle spot and doesn't go over the side of the car or anything but still don't like it when that happens.
  7. #7 Re: What's the deal with our gas tanks?
    I don't use the auto fill feature on the pumps, I always hold the trigger and just listen for it. That way it can't bubble up too high if it wanted too.
  8. #8 Re: What's the deal with our gas tanks?
    Feb 2013
    37.295091, -121.930053
    i call it paying 20 on your pump
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: What's the deal with our gas tanks?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    my fills up just fine ..
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  10. #10 Re: What's the deal with our gas tanks?
    Jan 2014
    AR
    Real cars fuel from the rear.
  11. #11 Re: What's the deal with our gas tanks?
    Sep 2014
    Worcester, MA
    I spent way too long trying to figure out how the OP was moving the pump around. You just meant the nozzle....
    And I have best luck by pulling the nozzle slightly out of the fillup tube, maybe 1/2" - 1", and then I can blast away at full volume.
    Although maybe moving the pump around would help too, I'll try that next time I fill up.
  12. #12 Re: What's the deal with our gas tanks?
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    I guess I just pull up to pump, take gas cap off, slide card, hit what gas I want, then put nozzle in all the way and put the auto fill thing on the pump on. I had a problem with the 07 gp I had, my 01 and my 08 g6 do not have this problem
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  13. #13 Re: What's the deal with our gas tanks?
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    My 04 has this issue 1/2 time Just move nozzle around till it works. Have been a few times I just wanted to set it on fire through
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  14. #14 Re: What's the deal with our gas tanks?
    Aug 2012
    Brainerd, MN
    The 07 i had, i would have to remove the gas nozzle about half way for it to work
  1. GM should've put baffles in the gas tanks...
    By SubwayGuy in forum The Rant Forum
    Last Post: 07-30-2015, 09:28 AM
  2. tanks projector build
    By Grandprix202 in forum Visual/Body Modifications
    Last Post: 06-28-2014, 08:20 PM
  3. 03 Bonnie - $2800 deal or no deal? 197K miles
    By Randall Carlisle in forum GM H Body
    Last Post: 11-14-2012, 10:01 AM
  4. Fuel Tanks
    By grandamle91 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2011, 02:12 PM
  5. how many gallons are our tanks?
    By k5greek in forum General Tech Discussion
    Last Post: 12-20-2010, 12:54 PM
