Thread: Transmission is acting up.. what could it be ? Please help
Results 1 to 5 of 5
  1. #1 Transmission is acting up.. what could it be ? Please help
    Aug 2015
    Detroit, Michigan
    Hello, I don't think it is slipping.. I believe its called shuddering ?
    It shifts fine until It gets hot, ( driving hard for about 30 mins - 1 hour ) then it starts acting up... then if I let it cool down for lets say 30 mins, Its fine again..
    I wouldn't say the gears are grinding either.. What could the problem be and how would I go about fixing it ?
    Maybe a solenoid ?
    Should I do a trans flush ?
    Or should I buy this one off my boss for $300 (130k miles on it)
    Thanks guys
    - Paul
  2. #2 Re: Transmission is acting up.. what could it be ? Please help
    Howell, NJ
    Don't do a transflush, it'll usually end up making things worse in these cars if it hasn't had a flush in a long time.
  3. #3 Re: Transmission is acting up.. what could it be ? Please help
    Mar 2014
    Tucson
    How many miles on the trans? How many miles on the fluid? What color is it? Any debris/grit in it?
  4. #4 Re: Transmission is acting up.. what could it be ? Please help
    Aug 2015
    Detroit, Michigan
    Quote Originally Posted by BrandonHall10 View Post
    Im sorry. I should have listed all the info..
    Engine/Trans/Body has 119k miles.
    I bought the car for $1650 back on July 11th, I love the car, Inside and out is extremely clean.
    The fluid was actually terrible looking, resembled oil very much but every week for two weeks now, I have been siphoning a quart out from the dipstick reservoir and then pouring a new quart in... Its not quite a red color yet but its getting better looking..
    Recent work I've done myself in the past week or two would be ..
    Oil change
    New Oil filter
    New Air Filter
    New Water pump
    Radiator flush and new antifreeze
    New Tires
    I bought new spark plugs but haven't installed them yet, I'll be doing this tomorrow.
    I believe I need to put new lifters on it as well.. Its making a ticking sound and im almost positive its the lifters.. Does anyone know off hand how much new lifters would run and how hard the job would be ? Pretty sure the front is easy, just remove the cover and install new, but the back lifters ?? I have to to rip half the engine apart huh ?
    thanks fellas, I appreciate your help so much !!
    -Paul
  5. #5 Re: Transmission is acting up.. what could it be ? Please help
    Howell, NJ
    What makes you think you need new lifters? You need to remove the upper and lower intake manifold to get to those. The rocker arms are right under valve covers, a lot of people get the two confused. However, I doubt you need either of those replaced.
    Sent from my SM-N910V using Tapatalk
  1. Transmission acting funny
    By kcirrab in forum General Tech Discussion
    Last Post: 04-09-2011, 10:11 PM
  2. Transmission acting weird during startup
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2011, 11:09 PM
  3. put in boost guage now transmission is acting up
    By tssmokefangtp in forum Introductions/Noob Questions
    Last Post: 12-23-2010, 03:38 PM
  4. HELP!!! Transmission acting horrible, bucking, stuttering, grinding, shifting hard.
    By Lsick7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2009, 10:09 PM
  5. 98 GTP acting up help!!!!!!!!!
    By Red_GTP in forum General Tech Discussion
    Last Post: 08-04-2008, 05:35 AM
