Thread: rpm drops when coming to a stop
Results 1 to 4 of 4
  1. #1 rpm drops when coming to a stop
    Jan 2013
    Texas
    When come to a stop my rpm drops and then smooths out. It drives smoothly on the highway. Starts up smooth too. I got a 2002 gtp. Any ideas?
  2. #2 Re: rpm drops when coming to a stop
    Aug 2011
    'Merica
    Clean you TB and your MAF with the appropriate cleaners. If that doesn't work, turn the car off, unplug the MAF and start the car. If it runs ok then you have a bad MAF.
  3. #3 Re: rpm drops when coming to a stop
    GrandPrix Junkie
    Mar 2012
    NC
    I recommend cleaning the IAC too when all this other cleaning occurs. Use only MAF cleaner for the MAF...carb clean is fine for the IAC and throttle body.
  4. #4 Re: rpm drops when coming to a stop
    IAC is part of the TB
  1. 1999 tranny goes to neutral when coming to stop
    By mhall in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-13-2014, 09:40 PM
  2. ABS ingauging when coming to normal stop - no lights on
    By albow77 in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2012, 08:33 PM
  3. Trouble downshifting when coming to a stop.
    By wytmyk420 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-31-2011, 05:04 AM
  4. RPM drops above 45 mph
    By guyute85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2011, 01:58 AM
  5. Clunk when coming to stop and/or accelerating
    By trailshredder in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2010, 05:43 PM
