Thread: Car running hot
Results 1 to 10 of 10
  1. #1 Car running hot
    Apr 2012
    Memphis, tn
    I have a 06 grand prix and its trying to run hot I changed the intake gasket, thermostat, I seen that the coolant in the radiator was brown so I got the radiator flushed out. What else could it be. If anyone could help I would appreciate it thanks
  2. #2 Re: Car running hot
    Did you bleed the air out yet?
  3. #3 Re: Car running hot
    Apr 2012
    Memphis, tn
    No how do I do that
  4. #4 Re: Car running hot
    Im assuming you filled the LIM with coolant first then stuck the thermo in and then the hose.
    So anyway.
    Turn the car on.
    Let it run up to operation temp or close to it
    Open the bleeder on the thermotat housing, only do 1-2 turns, you dont want to open it alot or take it off.
    You'll start to see air bubbles and coolant coming out, let the car run for a while till all the air is out, and a steady stream of coolant is coming out the bleeder.
    Once done, close the bleeder and take it for a drive and make sure it dont over heat, if it still bounces around and gets warm, bleed it again.
  5. #5 Re: Car running hot
    Apr 2012
    Memphis, tn
    Ok will try thanks
  6. #6 Re: Car running hot
    Apr 2012
    Memphis, tn
    Quote Originally Posted by Lilalvin84 View Post
    Ok will try thanks
    That didnt work it just streamed very little watercoolant came out as if something wasn't pushing it through could it be the radiator our water pump
  7. #7 Re: Car running hot
    Nov 2011
    Virginia
    Yea check the weep hole on your water pump, or the plastic coolant elbows on the alternator bracket
  8. #8 Re: Car running hot
    Apr 2012
    Central Florida
    Quote Originally Posted by CDooley View Post
    I own a 2006 Grand Prix and its headache trying to figure why the car runs hot. Today I had the plastic elbows replaced. The car ran way below half on the temp gauge. But when I went thru a drive thru to pick up a sandwich, the temp increased slightly above half. Scared me being I thought the problem was fixed with the elbows. I'm guessing I need a flush, a thermostat and the air bleed?
  9. #9 Re: Car running hot
    Quote Originally Posted by willjr View Post
    You do know that cars heat soak really fast when no air is going past the radiator right?
    Im gunna assume the temp went back to around half on the gauge after you started moving again.
    If so, its normal.
    But go ahead and get a coolant, it can never hurt anything.
  10. #10 Re: Car running hot
    Apr 2012
    Central Florida
    yes it did....sounds good, thank you
    If so, its normal.
  1. Running hot?
    By alewicki81 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-02-2011, 10:34 PM
  2. running hot
    By PatriotGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2010, 08:04 PM
  3. Who's running low 14's?
    By Louie3 in forum Off Topic Discussion
    Last Post: 08-02-2010, 09:24 AM
  4. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  5. who is running E85?
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 06:25 PM
