Thread: Hi I'm new and have a p0171 code, can you help?
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 78
  1. #1 Hi I'm new and have a p0171 code, can you help?
    Donating Users falconjohnd's Avatar
    Aug 2011
    new fairfield ct
    Just got a 98 GTP yesterday and have this code. I believe vacuum is tight because I tested with TB cleaner. Car doesn't have a diagram so I may have missed something. MAF looked fine but I cleaned it anyway, put in new PCV and Air filter. Previous owner says it was a recurring problem and he's a car guy you should have seen the ponchos in his garage. I have a scanner what data is in the norm? I also dropped a bottle of techron in the tank but that will take some time to have an effect. car runs really well despite code.
  2. #2 Re: p0171
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    First hello. Second try googling the code and see what it says if you dont have the book with your obd2
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  3. #3 Re: Hi I'm new and have a p0171 code, can you help?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I'd fine someone with a scanner/tuner to see what your LTFT's are. If they're +16.4 or what not it's probably a vac leak. It could also be your o2 sensor. I'm willing to bet it's a vac leak though.
  4. #4 Re: Hi I'm new and have a p0171 code, can you help?
    Aug 2011
    new fairfield ct
    P0171 is bank 1 lean code. Lots of stuff written about this code. I will run the diagnostic again today now that I know what to look for. Any clue where I can find the stats for all the measurements? LTFT is there and some other stuff but without knowing what numbers to look for it's kinda useless. If it is a vacuum leak other that throttle body cleaner what else can I use to check? Also any idea where I can get a diagram?
  5. #5 Re: Hi I'm new and have a p0171 code, can you help?
    If you are getting an LB1, your fuel trims are a given. It's not a question, it's a given.
    First stop is pulling the EGR tube. Don't waste the carb cleaner on it. You can't typically get any reaction from it, yet it can leak. Pull back the retainer piece that sits at the LIM and hold the tube to the light. Got a crack? Most do. I have one I'm going to get pictures of very soon. Just got it this weekend on a cam swap car. These tubes are such and issue, I stock up from a JY on them.
    Second stop, It's not the O2, the O2 is what reads the condition and tells the pcm about the lean issue. It might be a maf issue, never seen an O2 cause this code though. Because if the O2 fails, there are other codes that will get tossed.
    Battery cables. If they are corroded, dirty etc.. this can cause it.
    TB gasket.
    For more on this fun and exciting code that can plague you for months, search on P0171 and my name.
    I bought a ton of stock in this code.
  6. #6 Re: Hi I'm new and have a p0171 code, can you help?
    Aug 2011
    new fairfield ct
    Will check that tube if it ever stops raining. I know it's not the O2 because that's just the messenger of the bad news. Previous owner swapped the MAF already, I cleaned it again and so far after 80 miles it has stayed out. MAF didn't look dirty to me.... Wouldn't a bad TB gasket have showed up with the cleaner. should i open it up anyway and give it a good cleaning. One more Q. Would lower grade gasoline trip this light also?
  7. #7 Re: Hi I'm new and have a p0171 code, can you help?
    Aug 2011
    new fairfield ct
    theseEGR tubes there are two they are dealer parts?
  8. #8 P0171 back again!!!!
    Aug 2011
    new fairfield ct
    New EGR Tube, new TB gasket, new pcv valve, new fuel filter and a dose of techron to clean up any dirty injectors, and new MAF sensor and the code keeps coming back for more...... aggravation that is! If it's a vacuum leak it's a real small one because carb cleaner isn't affecting the idle. I don't believe it's the fuel pump car runs very well. Anybody got something new?
  9. #9 Re: P0171 back again!!!!
    Florida Tuner Z34Phoenix's Avatar
    Florida
    can you get a data log? have you tested fuel pressure? have you checked the fuel pressure regulator?
    96 Z34 (RIP LQ1 14.81@92.3) L36 Swap 14.9@91.5 www.cardomain.com/id/z34phoenix
    Topswap: P&P All,Si Valves,L76's,LW Pushrods,SD's,DHP PT PB 13.91@99.8
  10. #10 Re: P0171 back again!!!!
    GTX Level Member Deimos's Avatar
    iowa
    fuel too lean possibly an 02?
  11. #11 Re: P0171 back again!!!!
    Aug 2011
    new fairfield ct
    Had the car smoke tested. They are telling me my throttle body and upper intake manifold gasket are leaking....... I'm waiting on a new TB to arrive and I guess I'm doing a whole new gasket set might as well since the LIM is failure prone with the mileage on this car. Never took out a fuel injector though... I watched the video on this board good stuff but how do you take the injectors out?
  12. #12 Re: P0171 back again!!!!
    Florida
    They just pull out once u unbolt the fuel rail. I would buy new injector o rings just to be safe too.
  13. #13 Re: P0171 back again!!!!
    Aug 2011
    new fairfield ct
    got em thanks.
  14. #14 Re: Hi I'm new and have a p0171 code, can you help?
    Aug 2011
    new fairfield ct
    Well after two days work, yes two days! she's all back togather. I'm glad I changed LIM gaskets because they were toase. No water in oil amazing. Very clean car internally, no sludge or chocolate brownie inside the valve covers! I think I broke the vacuum hose that goes to the MAP which I'll replace or splice today. DuBob's video was great! Hopefully MIL will stay off now!
  15. #15 Re: Hi I'm new and have a p0171 code, can you help?
    Bastard Reptile's Avatar
    Kansas City, MO
    Bad vacuum boots on the manifold lines can cause this. It doesn't take much of a leak to cause this code to pop up from my experience. If the EGR tube wasn't the culprit, then I'd investigate the rest of the lines, even the o-ring that seals the top vacuum port on top of the supercharger.
  16. #16 Re: Hi I'm new and have a p0171 code, can you help?
    Agreed.
    John..did you check the battery cables?
  17. #17 Re: Hi I'm new and have a p0171 code, can you help?
    PCMO
    I was having the same code come on sporadically and once I replaced the fuel pump it has not returned.
  18. #18 Re: Hi I'm new and have a p0171 code, can you help?
    Aug 2011
    new fairfield ct
    I will check these boots next. Not sure where that port is that you mentioned. Is it that black plate on top that's bigger than the one that covers the PCV? Battery cables are clean and non corroded. The thing that is getting me is that even with a new MAF (did that Friday) and the other things I have done so far the the light comes on even before all of the monitors have reset from clearing the code. It stayed off for about 100 miles or so after the MAF was changed came on Saturday went off on Sunday came back last night. There are no driveability issues that I can tell and I've put about 700 miles on the car since I got it a week and a half ago. I think it's messing with me......
  19. #19 Re: Hi I'm new and have a p0171 code, can you help?
    Aug 2011
    new fairfield ct
    As far as the fuel pump goes... so far all the parts have been relatively inexpensive gotta believe this is not a cheap one so I'd like to know for sure before I buy one.
  20. #20 Re: Hi I'm new and have a p0171 code, can you help?
    The way to do that would be to check the fuel pressure. If it's low either the regulator is bad or the pump can not keep up.
  1. Engine Light on code P0171, IDLE SURGING!
    By balzi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2013, 01:51 PM
  2. p0171 code, AEM WB reads good AFR
    By JayGTP02 in forum General Tech Discussion
    Last Post: 08-14-2011, 12:11 PM
  3. code p0171 p0332 wont start now
    By juanathandavid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 05:29 PM
  4. code P0171 keeps coming back
    By grandprix01 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-22-2009, 01:33 AM
  5. P0171 set on decel//update has another code
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2008, 11:59 PM
