Thread: Easiest way to seal a sunroof
Results 1 to 2 of 2
  1. #1 Easiest way to seal a sunroof
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    The sunroof doesnt work in my regal. I can hear the motor run when i hit the switch and it moves the glass ever so slightly. I cant get it to seal in place, and there is a lot of wind noise coming from it.
    I would replace it, but there is a new headliner in the car, and i know it was glued in places. I want to seal it up. My thought is to get the window sealing silicone they use for windwhiields and use smoe of that.
    any thoughts?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Easiest way to seal a sunroof
    Jul 2017
    macomb mi
    you got class man haha I use some bathroom caulk or something already around the house but yea I don't see why it wouldn't work
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  1. Easiest fix for LED signals
    By Kilroy in forum Audio, Security & Visual Electronics
    Last Post: 02-04-2014, 11:12 PM
  2. which way is easiest?
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 08:09 PM
  3. What is the easiest way to pull a Motor???
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-12-2009, 12:56 PM
  4. whats the easiest way (rack)
    By jbmiller in forum General Tech Discussion
    Last Post: 01-04-2009, 01:29 PM
  5. Easiest HP gains
    By mikes_comp_g in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:17 AM
