Thread: Numerous issues? Bad Ground?
Results 1 to 3 of 3
  1. #1 Numerous issues? Bad Ground?
    Nov 2021
    canada
    hey guys own a 2001 Regal GS. When i got it, i noticed it has a few small issues.the horn dont work, drivers side heated seat dont work, airbag light is on. NOW here is what i done so far:
    -replaced the horn, didnt fix it
    -replaced drivers seat with a known good one, didnt fix it. *NOTE passenger side works fine*
    -covered the airbag light up with black tape, didnt fix it.
    -replaced clock spring, didnt fix anything
    -replaced heated seat switches...twice...didnt fix anything
    So now im thinking maybe a bad BCM? Ground? Are there any known bad ground locations on this vehicle? I also did a negative wire upgrade 0 gauged from the batter to the body and to the engine.
  2. #2 Re: Numerous issues? Bad Ground?
    St. Louis
    Have you checked the fuse for the horn?
    On the heated drivers seat, make sure the harness under it isn't broken somewhere.
    Have you scanned the car for codes? Might be able to narrow down the airbag light that way.
    Check the ground that attaches to the transmission bellhousing. Should be up front on a stud.
  3. #3 Re: Numerous issues? Bad Ground?
    everything fordman said.
  1. 2005 4t65E wheels spin off ground in drive on lift? No movement any gear on ground.
    By jj5428 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2023, 04:21 PM
  2. MAF ground?
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2017, 01:28 PM
  3. Amp Ground
    By X97prixX in forum Audio, Security & Visual Electronics
    Last Post: 11-11-2009, 08:14 PM
  4. Bad Ground???
    By jjokrm in forum General Tech Discussion
    Last Post: 01-25-2009, 07:44 PM
