i am working on my 2000 grand prix gtp. i had to replace the driver side brake line about 1/2 way down the car through the portioning valve and back to rubber hose. i replaced the line on both sides of the portioning valve, i had no choice it was rotted badly. i used a standard flaring tool. i tightened it down really good but it still leaks bad. i dont think GM used a standard flare inside the portioning valve. how do i fix this thing? can i buy a special tool to make the proper shape of the flare? i had to re-use the old fitting because the new fittings i had that i was using everywhere else were not same size as what was on the portioning valve.
