Thread: Abs and Trac off/on
Results 1 to 12 of 12
  1. #1 Abs and Trac off/on
    Sep 2012
    fort Wayne, in
    Ok so recently I've been having the abs and Trac light coming off and on. One time I was on when I started the car and stayed on. I drive about 30-40 minutes to work and the other morning it didn't come on at all. I'm guessing a dirty plug somewhere but what should I check? Brakes and rotors are brand new with maybe 5k on them
  2. #2 Re: Abs and Trac off/on
    One of your hub bearings is going out, find someone with an abs scanner and that should tell which one it is.
  3. #3 Re: Abs and Trac off/on
    SWPA
    If its random I bet its a broken harness.
  4. #4 Re: Abs and Trac off/on
    Sep 2012
    fort Wayne, in
    I know one of the codes that got thrown a few weeks ago was wheel speed sensor but wouldn't it have tripped the abs and Trac lights then?
  5. #5 Re: Abs and Trac off/on
    Sep 2012
    fort Wayne, in
    I threw on an old set of tires onto the car and noticed a hum when I'm above 35 but I figured it was the tire having a wear spot or something.... so maybe it's the hub going bad....?
  6. #6 Re: Abs and Trac off/on
    Quote Originally Posted by buschegt View Post
    Yes the wheel speed sensor will trip the abs and track lights, that is what the wheel sensor is for. Whatever one it said it was for that is the one that you need to look at.
  7. #7 Re: Abs and Trac off/on
    Sep 2012
    fort Wayne, in
    I can't really go to a junk yard and grab a wheel hub and throw it on can i?
  8. #8 Re: Abs and Trac off/on
    SWPA
    You can but its not the smart way to do it.
  9. #9 Re: Abs and Trac off/on
    Jan 2014
    AR
    Be sure all the plugs are intact, too. Once the factory harness shroud gets crumbly, more water can get into the connector than is good. Fixed one with electrical tape.
  10. #10 Re: Abs and Trac off/on
    Aug 2013
    McDonald PA
    I gotta figure out what side mines on and tear into it. It's irritating me having those lights on and dinging.
  11. #11 Re: Abs and Trac off/on
    Sep 2012
    fort Wayne, in
    Can they seize up if not replaced?
  12. #12 Re: Abs and Trac off/on
    SE Level Member Aeroheadcww's Avatar
    Williamsburg, Ky
    I had this issue, changing the hubs didn't help. What I ended up doing was cleaning each connector with contact cleaner (aerosol), sensor cleaner should work also. Then I used some contact grease with copper in it and put it into each female connector and put them back together, no more problems. Not sure where you can get the copper grease from, my dad got it from GE when he worked maintenance there. There is a chance you have harness damage but try this first.
    _____________________________________________
    '05 CompG - 3.6 Pulley, ZZP PCM, K&N drop in, Customized SD Headers, TEP Street/Strip tranny, ZZP STBs, ZZP Coilovers, GXP front brakes
  1. Abs/trac off
    By Wingsfreak9 in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:52 PM
  2. ABS/Low Trac
    By Below Average Joe in forum General Grand Prix Discussion
    Last Post: 06-14-2012, 10:32 AM
  3. Trac off?
    By trigun87 in forum General Tech Discussion
    Last Post: 05-23-2010, 12:14 PM
  4. No ABS or Trac
    By Hamsalad2 in forum General Tech Discussion
    Last Post: 04-06-2010, 03:00 PM
  5. Abs/trac off
    By runn141 in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2010, 12:32 AM
