Thread: zr1 or z28 carbon ceramic rotor brake swap.
Results 1 to 9 of 9
  1. #1 zr1 or z28 carbon ceramic rotor brake swap.
    Mar 2015
    Aurora, CO
    Started this conversation on the cts-v brakes thread. Guess it's time to start my own. Quick synopsis I have one front rotor on the way from the dealer. Still working on finding part number for the caliper. This is going to be 15.5 in front carbon ceramic 2 piece rotor and rear 15.3 in 4 piston set up. This is going to be an expensive and time consuming process but i appreciate everyone's input. Went to the local parts store today and picked up some factory gtp rotors. I'm hoping to modify to create my own gtp hat section that will mate to the carbon ceramic disc ring. Once I have a working prototype I will be remachining using either stainless or aluminum. Another option I am looking at is modifying gtp wheel bearing hub assemblies to accommodate a 5x120 bolt pattern. Has anybody else had any success with this as a means of changing bolt patterns? Rotor should be here late next week. Pics coming soon!
  2. #2 Re: zr1 or z28 carbon ceramic rotor brake swap.
    SE Level Member 95naSTA's Avatar
    Philly
    I had Baer 2-pc rotors re-drilled to 115x5. The 120 bolt pattern is too tight to fit on 115.
    Contact any company that re-drills wheels for this. It should be $50 or less per rotor.
    95 Bonneville SLE: L36/F40/E39. 98 Infiniti i30: VQ35HR/5MTVLSD. 07 Ducati Monster S2R 800: DS1000 swap. 74 Yamaha DT175: Brap.
  3. #3 Re: zr1 or z28 carbon ceramic rotor brake swap.
    why another new thread?
  4. #4 Re: zr1 or z28 carbon ceramic rotor brake swap.
    Mar 2015
    Aurora, CO
    Quote Originally Posted by 98GrandPrickVet View Post
    I think the guy that started the CTS thread got mad cause I was getting off topic.
  5. #5 Re: zr1 or z28 carbon ceramic rotor brake swap.
    Mar 2015
    Aurora, CO
    I know I can redrill the rotor but can I redrill the wheel bearing to change the root cause of the problem to 5x120? Then I would b able to use the rotors and wheels without modification.
  6. #6 Re: zr1 or z28 carbon ceramic rotor brake swap.
    it was edited by a mod and now another new thread is why im asking
    edit: also please use the edit button when your the last one to post it keeps threads condensed and not 30 pages of same person commenting. sorting through multiple threads and back to back comments is nonsense.
    thanks.
  7. #7 Re: zr1 or z28 carbon ceramic rotor brake swap.
    Philly
    Missed the part about you saying you want to run a 5x120 wheel..
  8. #8 Re: zr1 or z28 carbon ceramic rotor brake swap.
    Mar 2015
    Aurora, CO
    Yeah it would make finding wheels to fit over these brakes a whole lot easier!
  9. #9 Re: zr1 or z28 carbon ceramic rotor brake swap.
    Mar 2015
    Aurora, CO
    thanks.
    Sorry I am new to forums. I have no idea what u r talking about...
    oh ok I think I see what u mean. Edit instead of having another post. Makes sense now. Thanks!
  1. Not GP related: RWD disk brake rotor swap, change in bolt pattern
    By GR8racingfool in forum Brakes/Suspension/Chassis
    Last Post: 11-28-2010, 10:26 AM
