Thread: Massive inprovement in front end feel for 50$
Page 8 of 9 FirstFirst ... 6789 LastLast
Results 141 to 160 of 166
  1. #141 Re: Massive inprovement in front end feel for 50$
    Aug 2016
    Lethbridge, AB
    Will the K200787 bushings fit my 2007 GT's stock LCA's? Or is this a Series 2 thing only? I've been driving around for a couple weeks annoyed about the boxy steering performance on my 2007 GT, then I saw this thread and thought OH BOY I NEED THAT, but everyone here seems to be talking about their Series 2 GPs and I feel left out. :<
  2. #142 Re: Massive inprovement in front end feel for 50$
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yes they will Fit. get poly urethane stab links and sway bar bushings also. Strut tower braces help a bunch also.
    MOOG K700527 {#10285683, 10403402} Problem Solver Info
    Front; OEM Type; Includes Polyurethane Bushings And Solid Metal Sleeve For Enhanced Performance. Barrel Nut Allows For Easier Installation.; 34mm Sway Bar Diameter
    $5.43
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  3. #143 Re: Massive inprovement in front end feel for 50$
    Aug 2016
    Lethbridge, AB
    Alright, so when I place this order I should be looking at two K200787's (front left/front right), two K700527's (also front left/right), and two strut tower braces ?? Do you have a part number? The Moog website is a nightmare and this stuff being all Greek to me doesn't help much. Rock Auto is a bit easier to navigate but I don't see "strut tower brace" per se.
  4. #144 Re: Massive inprovement in front end feel for 50$
    GTP Level Member
    Jun 2016
    Cleveland ohio
    The strut tower brace is from a Buick. You will have to drill holes for it to fit. My 04 comp g already had the holes drilled from the factory. Here is a link for those bars. Do some searching to find the best deal. http://paceperformance.com/i-6484850...wer-brace.html
    And yes 2 of each of the parts you mentioned. Same part # for both sides.
  5. #145 Re: Massive inprovement in front end feel for 50$
    Aug 2016
    Lethbridge, AB
    Awesome, thanks a bunch.
  6. #146 Re: Massive inprovement in front end feel for 50$
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quick question. These get pressed in through the top of the LCA, correct? The op pic has them going both ways. Does it matter?
    GPONA #1 Cyber Bully
  7. #147 Re: Massive inprovement in front end feel for 50$
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    It might not make a difference, but I'd do it through the top just cuz the factory put the bushings through the top of the LCAs, and they probably had a reason to.
    Most likely reason is cuz it was easier or faster.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  8. #148 Re: Massive inprovement in front end feel for 50$
    Banned
    Quote Originally Posted by blackspike2710 View Post
    I just did these and I put them in the same way the factory did. One goes in the top and the other goes from the bottom. The arms are basically the same just flipped from side to side. I had them pressed in but just some random moving of these and the bushing fell out. My fix was to weld them in with a few tacks.
  9. #149 Re: Massive inprovement in front end feel for 50$
    Oct 2014
    Frederick, MD
    Quote Originally Posted by ebk231 View Post
    Mine were both through the top, and it looked like they had been there since 2003... but now I just don't know. lol
    I also had the 20mm front sway and no tab on the back of the LCA, so that might have been it.
  10. #150 Re: Massive inprovement in front end feel for 50$
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    I put mine in the same way and the same thing happened to me, and my fix was the same LOL. No worries after that.
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  11. #151 Re: Massive inprovement in front end feel for 50$
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    The Moog K200787 Vertical Bushing gets pressed in from the bottom of the driver's side control arm, and through the top of the passenger side control arm. It does make a difference in how the K200787 bushing works. I have spoken to a number of mechanics who have installed bushings and they confirmed this. If you note, the OEM bushings were installed that way
  12. #152 Re: Massive inprovement in front end feel for 50$
    Aug 2013
    Pittsburgh, PA
    For those who do all their own mechanical work and are interested in building their own tools for repetitive jobs on the w-body platform (and others as well) here is a good video: https://www.youtube.com/watch?v=qhrY7clDIGE
    Also, read through this: http://www.suspension.com/blog/how-t...-a-press/#tips
  13. #153 Re: Massive inprovement in front end feel for 50$
    Banned
    Quote Originally Posted by NotEnoughGPs View Post
    The Moog K200787 front Control Arm Bushing gets pressed in from the bottom of the lower control arm. It does make a difference in how the K200787 works. I have spoken to a number of mechanics who have installed bushings and they confirmed this
    The video on page one show a cutaway of the bushing and its looks to be the exact same top or bottom. The control arms have a taper to them where the bushing is. The factory bushings are pressed into that taper and that is the way I would do these. The way the controls arms are designed puts that taper on the top of one and the bottom of the other.
  14. #154 Re: Massive inprovement in front end feel for 50$
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    Ok I watched the videos. Has anyone attempted using the ball joing tool or the tools in the video on the wbody control arms?
    I am plannng on doing this but I wonder if the control arm will collapse on install.
    TIA
  15. #155 Re: Massive inprovement in front end feel for 50$
    Aug 2013
    Pittsburgh, PA
    The driver's side vertical (front) bushing gets pressed into the control arm from the bottom, and the passenger side vertical (front) bushing gets pressed into the control arm from the top
  16. #156 Re: Massive inprovement in front end feel for 50$
    SE Level Member klimtrack's Avatar
    Sep 2014
    ChiTown
    Both of mine are pressed from the bottom. It's gonna be a year in the summer but no issues so far.
    2002 Regal GS
  17. #157 Re: Massive inprovement in front end feel for 50$
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Quote Originally Posted by alacran View Post
    TIA
    The reading makes a point about using the "proper" tool.
    I think they rent those at O'reilly, and sell them at Harbor Freight for like $50.
    A holesaw? C'mon now.
  18. #158 Re: Massive inprovement in front end feel for 50$
    SE Level Member dirtyape's Avatar
    Dec 2014
    Lomita,Ca
    Great thread, thanks to everyone that has figured this stuff out. I could use your opinions
    I have a 97 gtp, southern california car its whole life. The lca's have no rust or any kind of blemishes that I can see. 203k miles. I have had the rat suspension kit on the car for about 125k mi. Do you think i should get all new lca's or just the bushings?
  19. #159 Re: Massive inprovement in front end feel for 50$
    Banned
    Quote Originally Posted by dirtyape View Post
    They can be a pain in the butt to rebuild. I did it though and I used factory arms. I used the moog problem solver bushing ac delco for the other bush and the ball joints. The car feels better than ever. The rest of my suspension is also new. The car just did not feel right til I did these controls arms and I had put a newer set of moog controls arms in a few years ago. The steering feel lighter and responsive and it seems to stay balanced through curves. I have owned the cars since new and this is one of my favorite mods.
  20. #160 Re: Massive inprovement in front end feel for 50$
    Dec 2014
    Lomita,Ca
    thanks for the reply. what do you guys think of these moog ball joints https://www.amazon.com/Moog-K5331-Ba...+Prix+88965333
    vs the ac delcos from gm parts direct?
    and these moog bushes
    https://www.amazon.com/dp/B001CA2JWY...=1Y567Q13HA2MM
  1. loud humming in front end and can feel vibration in my feet
    By brian19876 in forum General Tech Discussion
    Last Post: 07-09-2014, 11:12 PM
  2. massive flat spot into third WOT
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2011, 09:24 PM
  3. Massive Oil Leak
    By 2000superGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2011, 11:17 PM
  4. Massive water leak
    By hahaha38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2010, 07:19 PM
  5. WOAH! Massive Oil Leak!
    By CSteen85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2010, 12:30 AM
