Thread: massive flat spot into third WOT
Results 1 to 15 of 15
  1. #1 massive flat spot into third WOT
    Banned
    Jun 2011
    02' GTP has a massive flat spot when it shifts into 3rd at WOT...
    What could this be? Could it be from not running a rear o2 sensor?
  2. #2 Re: massive flat spot into third WOT
    Omaha, NE
    No, the rear 02 is for emissions only.
    Can you describe "flat spot" a little better?
  3. #3 Re: massive flat spot into third WOT
    Akron Ohio
    For 2000 And Up I believe the rear o2 is important 97-99 not so much
  4. #4 Re: massive flat spot into third WOT
    Omaha, NE
    I don't have one on my 04. Its either plugged or my wideband is in it.
  5. #5 Re: massive flat spot into third WOT
    Akron Ohio
    I dont know about the 04 difference, Just the 97- 03
  6. #6 Re: massive flat spot into third WOT
    Banned
    Jun 2011
    alright. i jump on the highway and hammer it. let second gear crank out.
    when it shifts into third it dogs out bad, if i keep it floored it bogs for like 3 seconds, then pulls hard again..(under WOT the whole time)
    the 01+ cars need the rear o2..something about cat diagnostics, and without a rear o2 on 01+ it will run pig rich.. what i dont get is it only does it in third gear at WOT..? could it be knock retard?
  7. #7 Re: massive flat spot into third WOT
    cat diagnostics is when cruising.
  8. #8 Re: massive flat spot into third WOT
    Banned
    Jun 2011
    so then its prob not cat diagnostics...
    would a person feel knock retard?
  9. #9 Re: massive flat spot into third WOT
    Banned
    Jun 2011
    still have this prob cant figure it out
  10. #10 Re: massive flat spot into third WOT
    Solved your problem...don't go faster on the street than you can trap in the 1/4.
    Which shouldn't be over 100.
    Therefore...quit going into 3rd @ WOT.
    Or, it's knocking like a b1tch...there is TONS more load on the motor in 3rd gear than in 1st/2nd...my advice...get a way to scan it and see what is going on and stop beating on it.
  11. #11 Re: massive flat spot into third WOT
    SE Level Member SMazza's Avatar
    Jun 2011
    Eastern Pennsylvania
    It could be knock retard.
    It also could be misfires under boost. How old are your plugs and wires? Have you checked the plug gaps lately?
  12. #12 Re: massive flat spot into third WOT
    Banned
    Jun 2011
    plugs are a month old..wires almost a year..
    would knock retard feel like a bog?
    i rarely do over 80
    "stop beating on it"... i dont beat on it much.. i have only made it do this a handful of times. i am afraid this IS knock retard, i dont want to blow it up..
    if i could just find someone to scan
    could it be from a shotie exhaust system with a few splices?
  13. #13 Re: massive flat spot into third WOT
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Try checking fuel pressure. Maybe as you run it up the psi is slowly dropping causing it to stumble, then build up some psi to get things running. If you can, check psi while this happens, but after scanning first.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  14. #14 Re: massive flat spot into third WOT
    Banned
    Jun 2011
    it doesnt stumble, just fades out then comes back
  15. #15 Re: massive flat spot into third WOT
    its torque management. if you tune it that will go away, but then so will your transmission.
  1. Massive Oil Leak
    By 2000superGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2011, 11:17 PM
  2. Coolant leak spot found whats the fix
    By davhamm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2011, 12:06 PM
  3. Spot paint jobs?
    By Edagimo in forum Visual/Body Modifications
    Last Post: 09-28-2010, 09:46 PM
  4. Can you spot the 'Wootage'?
    Last Post: 05-05-2008, 08:00 PM
  5. Can you spot my new appearance mod?
    By DuBob in forum Visual/Body Modifications
    Last Post: 04-10-2008, 09:04 AM
