Thread: Replaced Calipers
Results 1 to 17 of 17
  1. #1 Re: Replaced Calipers
    Aug 2013
    arlington, tx
    Yea I kept an eye on the reservoir while bleeding and made sure it didn't go dry. Now i'm the type that likes to know why things work the way they do instead of just how they should work. So with that being said, why do you have to bleed the brakes in that certain order? Are all the brake lines eventually tied in together at a certain point and that comes into play or what?
  2. #2 Re: Replaced Calipers
    Technically, you should bleed all four corners, starting with the RR, LR, RF then LF
    like bill said. ^^^
  3. #3 Re: Replaced Calipers
    back and front brakes are separate. ( unless the master goes dry, then they all "need" to be bleed, along with the master) but always start at the furthest away wheel.
  1. CTS v calipers????
    By sandobar in forum Brakes/Suspension/Chassis
    Last Post: 04-26-2012, 09:14 AM
  2. C5 Calipers
    By Suaveat69 in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2010, 09:59 PM
  3. C5 calipers how much would you pay for?
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 09-05-2008, 05:43 PM
