Thread: Sounds like a wheel bearing, but I'm not sure...
Results 1 to 6 of 6
  1. #1 Sounds like a wheel bearing, but I'm not sure...
    Feb 2013
    Missouri
    So my mother in law just bought this 99 GP GT, and it seems pretty solid. A few problems here and there, nothing I can't handle. It sounds like it's got a bad wheel bearing in the back while cruising, but they're both tight once they're in the air. The PO blamed it on the GXP brakes he put in the back (but stock 11 inch fronts? lol), which I call BS. ABS lights aren't on or anything, and they all roll smooth. The only thing I can find is on the driver side rear when I push in on the top of the tire it moans as it turns. Hard to explain, I think that this is the bad bearing, but I wanted a few opinions before I replace it. Kind of hard to explain the sound, so I took a video of it. That's right, we have that kind of technology these days:
    https://www.youtube.com/watch?v=PqfO04mK43Q
    It's my mother in law's car so you can understand that I don't want to be wrong, lol.
  2. #2 Re: Sounds like a wheel bearing, but I'm not sure...
    Simple way to know for sure. A wheel bearing isn't going to typically get horrible or hurt anything else on the car/fall apart. Therefore if you let it go a bit longer, it should show itself better.
  3. #3 Re: Sounds like a wheel bearing, but I'm not sure...
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    I just did my son's 98 Monte Carlo that had a bad rear wheel bearing. It had a definite hum that got louder as you accelerated. Everything initially was tight so I pulled the wheel off, then thought it may just be pads against the rotor. Took the pads off to find them showing hardly any wear. Once the pads were off and you could spin the wheel on its own it was very clear the bearing was bad. It sounded like marbles rattling around behind the wheel.
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  4. #4 Re: Sounds like a wheel bearing, but I'm not sure...
    Aug 2013
    McDonald PA
    I didn't think mine was bad. It just had a little seizing no abs lights. Just ordered a timken one cause I have a bad vibration and shake on the highway at 65
  5. #5 Re: Sounds like a wheel bearing, but I'm not sure...
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    Have you determined what was causing the noise in the '99 GT?
    You said that you checked the rear wheel bearings for any play and they both were tight. I have seen wheel bearings that were tight and still made noise. With the tires removed and the emergency brake off, try spinning the bearing and check for any sign of roughness. I replaced both rear bearings at 100,000 miles in my 40th Ann. GP and installed Timkin bearings (the original equipment bearings were not even bad, but I was installing new struts, springs, trailing arms, rotors, calipers, so I figured what the hell replace the rear bearings also) At 180k miles, the rear driver side bearing started making noise and after driving with this bad bearing for a thousand miles or so, it got really bad. With my GP in the air, I could not detect any play in the wheel. But with the drivers side wheel removed, I tried spinning the bearing and it was hard to turn and I could feel the roughness of the bearings.
    Also, check the e-brake shoes. I also have GXP brakes on my 40th ann. and when I replaced the wheel bearing, I removed the e-brake shoe. I removed the shoe with the wheel bearing still in place not knowing that the bearing needed removed first, then the e-brake shoe. After having the rear GXP rotors cleaned up and reinstalled, the e-brake shoe was tight inside the rotor. It made lots of noise when driving, sounding like the one on the Youtube video that you were referring to. The only way I could correct this was to remove the e-brake shoe and the noise was gone.
  6. #6 Re: Sounds like a wheel bearing, but I'm not sure...
    Feb 2017
    FL
    My 98 GTP SC makes the same noise. Once I get up to 30 mph the knocking sounds starts. Sometimes it stops knocking at 50+ mph. My steering wheel shakes even my car shakes. It's reallyyy annoying .. I replaced the front passenger tire a few times. One man shoke I believe what is the wheel bearing. Could it be loose? Or replace it?
  1. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  2. Wheel rocking still... already changed wheel bearing. Ideas?
    By jmn in forum Introductions/Noob Questions
    Last Post: 09-30-2013, 09:27 AM
  3. ABS wheel bearing/hub on non ABS car?
    By Captain Bravo in forum Brakes/Suspension/Chassis
    Last Post: 01-01-2011, 03:15 PM
  4. Steering Wheel Sounds and No A/C
    By CSteen85 in forum General Tech Discussion
    Last Post: 08-02-2010, 07:10 PM
