Thread: Cable mod with ubolts?
Results 1 to 4 of 4
  1. #1 Cable mod with ubolts?
    gardner,mass
    Could i just jack the car up in the rear and put a ubolt around the strut and drill some holes and put the ubolt threw there?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Cable mod with ubolts?
    Not following your idea.
  3. #3 Re: Cable mod with ubolts?
    gardner,mass
    Ok so the cable mod you just put it threw the sway bar bracket, then drill holes in the inner wall of the body to hold the strut down while extended.
    Im thinking of just taking a couple long ubolts i have at work that are like 10 inches long. Wrapping it around the strut above the bracket then drilling 2 holes and bolting the ubolts in that way instead of dealing with the lines. Ill try it and see if it will work.
  4. #4 Re: Cable mod with ubolts?
    Oct 2011
    Toledo, OH
    Still not clear on what you are doing. What's this mod do?
    EDIT: Google is my friend.
    No, Ubolts are a bad idea because they won't have ANY play and you'll just rip a hole in your body.
    7"
  1. DHP cable set up help
    By Scottydoggs in forum PCM Tuning
    Last Post: 08-08-2014, 11:46 AM
  2. Abs cable
    By jc71corvette2 in forum Brakes/Suspension/Chassis
    Last Post: 10-26-2013, 03:23 PM
  3. cable/satellite
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 04-02-2012, 01:17 PM
  4. transmission cable
    By tod1d in forum The Rant Forum
    Last Post: 01-07-2011, 11:24 PM
  5. OBDII Cable
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 03:22 AM
